Old 03-24-2003, 08:04 PM   #391
ozone's Avatar
hi...
wat is the REQUIRED hop up to make it competive in TCS?
other than the following:
1) speed tune gears/tb01 modification
2) motor mount
can anyone shed some light to the pros of the hop ups gonna b recommended....note it must b TCS legal hop ups
ozone is offline   Reply With Quote
Old 03-24-2003, 09:41 PM   #392
Hi Ozone,
Well if you're on David Jun's level you can almost race it out of the box and win. For the mere mortals here I think you'll need at least a set of gears appropriate for the class, speed tuned gears are the only option AFAIK as the TB gears should not be legal, heatsink motor mount, lightweight diffs, universals in front preferably all around, lightweight shaft & lightweight gears for the gearbox, low friction damper pistons and rods, a racing spring set and Tamiya Type A F201 tires. I think this is all you really need, everything else is just freeing up the drive train and suspension.
Cheers/Chip
chiplouie is offline   Reply With Quote
Old 03-30-2003, 06:46 PM   #393
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
I just want say, Everybody the F201 is a cool car
Maybe some of you might to want share your set up with other
who got a the best set up and show me what you got
OVA is offline   Reply With Quote
Old 03-30-2003, 07:09 PM   #394
Ova: check out http://www.formula1-rc.com for pics and setups
TheNige is offline   Reply With Quote
Old 03-31-2003, 08:02 PM   #395
ozone's Avatar
chiplouie: thanks for the info....
is there any legal tcs mod to help the motor stay cooler, areadi added the alum motor mount...thanx for any help
Old 03-31-2003, 08:12 PM   #396
Hi Ozone,
You can add heatsinks to the car like I did. But with the kit chassis you may not be able to fit them both without some work to clearance the heatsinks to fit the chassis and brace.
Cheers/Chip
Old 03-31-2003, 08:42 PM   #397
ozone's Avatar
chiplouie: saw ur car... damn cool... but its not tcs legal tried doin the same...but cant fit unless i shave some parts...but not sure if tats allowed....
any other trick?
Old 04-04-2003, 05:30 AM   #398
I just installed the TB-01 gear mod and I'm using the kit sport tuned motor. I notice the tires balooning when at speed (off the ground). Is the TB-01 gear mod suitable to be used with the kit motor? Btw, I'm still using the stock Tamiya tires.
Morpheus2be is offline   Reply With Quote
Old 04-04-2003, 09:43 AM   #399
SpeedTech's Avatar
Hi Guys,
We got more F201 car kits (ferrari) and hop-ups in stock. Also, photos from the last round of F1RL is updated online.
Morpheus2be,
You should tri some pit shimizu F201 tires, or the Tamiya Type A upgrade tires, those will work a lot better than the kit ones.
Chip,
so when are we going to see that thing run?
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-04-2003, 10:37 AM   #400
Hi Steve,
As you know I've been scarce, you haven't seen me spending wads of money at the shop lately. I had some real work to do to rebuild my R/C account. Then I had a photo shoot with Sugar Ray (the pop group), for Atlantic records and a couple of cover shoots for two Japanese music magazines.
Do we have a date for the driver's meeting? Please include me if it has not already happened! I want to run the series in the next "season." I have the car pretty much ready to give it a go with a few minor issues to clean up.
I'm also writting a set-up article on the F201 chassis with images and a short review of the 3Racing/Eagle CF chassis and hard parts. So I have been spread kind of thinly with my usual home stuff to boot.
Cheers/Chip
Old 04-05-2003, 05:27 AM   #401
Okay, I got a chance to try the TB-01 gearing with the stock sport tuned motor. Car runs fine and fast. I used a 1700mAh sports pack and after the pack dumped, I checked the motor. It was cool to the touch. However, my ESC (M3 Tempo) was quite hot. Is this normal?
Old 04-05-2003, 11:31 AM   #402
psycho's Avatar
It seems odd to me that your esc would get hot when running the sport tuned motor. That motor is just a 540 with advanced timing. Warm is ok, but it shouldn't be hot.
psycho is offline   Reply With Quote
Old 04-08-2003, 07:53 AM   #403
KiwiKid's Avatar
Default Another example of the Beautiful Eagle Racing Chassis
KiwiKid is offline   Reply With Quote
Old 04-09-2003, 04:13 PM   #404
Claydoh's Avatar
Send a message via AIM to Claydoh
Looks awesome. I bet with the stiffer arms, it's whole new car.
Claydoh is offline   Reply With Quote
Old 04-09-2003, 06:26 PM   #405
KiwiKid's Avatar
I will only get to test it this weekend, but will let you know what the ride is like. It certainly feels more solid all round.
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
