Old 03-12-2006, 12:32 PM   #2356
hpipro321's Avatar
Originally Posted by TMHippo
Hi All F1 Fans, how about those V8 today Go Cosworth.
Have you tried to install a Orion li-po battery into any of your carbon F1 Chassises yet and if so how does the car run. I see Long F1 racing in the future
Rodney
the lipo batteries fit in the car but u have to take them out of the case or do some heavy modding to the battery slots
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 03-12-2006, 02:39 PM   #2357
Marty Peterson's Avatar
R/C Tech Charter Subscriber
Well they fit just fine in the MLP Carbon fiber LTO Chassis. I sent one out about 2 weeks ago but our battery hold downs work better than the for chassis on the market. and no moddsssssssssss!
Here for the fun of it!
Selling HPI F10 Front Knuckles and Complete Rear Axles W/Diffs Ball and Gear.
W/12mm TC Hubs & W/14mm F1 Hubs Good for std bearing Pans cars. STD Bearings!
eBay item number: 200947192161,200947193175,200947187493
Marty Peterson is offline   Reply With Quote
Old 03-15-2006, 01:56 PM   #2358
Here is the Front end of the F2006F1 car 2WD Belt Drive car.
We are still testing shocks at this time.
Next week the rear end pictures will be posted.
And the finished car the following week!
you will also notice our Anti roll system!
This will allow us to run a smaller shock and lighter spring combo.
This will keep the chassis stable in the corners GONE! is the unwanted chassis roll you get with the F201 and other F1 Cars!
We will also use the same setup on the rear of the car.
This will let you tune the chassis and suspension to a true setting with No chassis roll or chassis flex!
So you make the chassis suspension and tires do what they were made to do!
See chassis Flex is like a handy cap you might not have the right setup on the car but the Chassis flex will allow you to run it up front. So if you have no flex and a true setup for the car you will be that much faster!
Old 03-15-2006, 03:39 PM   #2359
ford_racing's Avatar
Send a message via MSN to ford_racing
Looking very nice Marty, being RWD only what is the target weight of the chassis ready to run including all electronics?
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 03-15-2006, 04:10 PM   #2360
I think it will be around 800 to 900 Grams But I will not know it I am done with everything and happy with it Plus there will be Hopup parts to make it lighter and faster! I guess 1.8 pounds to 2 pounds
Old 03-16-2006, 04:07 AM   #2361
Patriiick's Avatar
nice pics of the roll bar system.. love it..
Reminds me of the RB system in the big 1/8th scale F1 kyoshos
Now, marty, we need to talk..
What kind of bribe do we have to send your way for you to show us the REAR of this thing ?
Patriiick is offline   Reply With Quote
Old 03-16-2006, 05:32 AM   #2362
Well I have changed the rear 2 times now and doing it again I tested the car yesterday and was not totaly happy with it.
So I will make New motor and Diff mounts and when I have the final shap I want and it handles like I want I will post pics of it Sorry I should be Done soon thinking maybe I am looking for it to do something it can't
Here look at these for a bit!
Old 03-16-2006, 06:01 AM   #2363
Birky's Avatar
The attention to detail on the last prototype is amazing. Great work Marty.
Smash 'EM! F1 Racing: WA's Home of Fun in Formula 1 RC Motorsport.
Birky is offline   Reply With Quote
Old 03-16-2006, 06:09 AM   #2364
Thanks do you think Benetton would mind
Old 03-16-2006, 06:25 AM   #2365
I ithnk the car in that photo was a Benson and Hedges not a Benneton, a nice pic either way though
ARC R11
Yokomo YRF001
AE B5m
Old 03-16-2006, 06:28 AM   #2366
They were talking about the pic in the past post Butt Yes it is a good Rear end Design!
Old 03-16-2006, 08:59 AM   #2367
Patriiick's Avatar
I agree about having a stiff chassis, but remember that real F1 cars have SOME flex built in also
However, when you look at a regular F201, it s all a bit silly. The suspension binds like mad and the shocks and arms do not work like they should.
I would be awesome also to "close" the area between the topdeck and lower deck in order to have a monocoque "look".
Did you consider doing a raised front section (purely for looks.. ) ?
What about dual motor ??
Old 03-16-2006, 08:32 PM   #2368
My first Design 2 years ago was of a monocoque Design is was a high nose molded tub Design car It is what we called True scale F1 R/C cars/ but after going from paper to Cad to just a chassis would be about 5000.00 USD for the mold and first layup and all we would have is a chassis. even with this currant Chassis we wanted it just like the real F1 cars even this one I had planed on stopping the lower chassis just behind the front wheels. but it has to much flex.
But I have been taking this company that way and I am sure one day I will get it to that point But for now we walk before we run! as they say.
Now from what I have found that there is not much flex in a F1 Chassis at all.
The suspension flex and tire design is what makes the car so good in the corners.
And a email I got back from a former Benetton team member told me after 1988 the chassis would see less chassis flex over the years and today there is not much flex at all Plus when I was in Indy this past year I talked with 3 teams on this very thing and they told me the tires do most of the work that they were like the shock and springs for the car.
He also told me to watch the cars as they go into a corner and the inside front tire might lockup because it is off the ground or under less load that there is no flex to the chassis at all when you are talking about a 60 to 80 mm diffrance in the left rear tire to the right front under a load as in going into a corner! Or when they have a flat in the rear tire the front comes off the ground Now in the day of active suspension the active system would adjust for this and a driver wouldn't even know he had a flat till it was to late so they put electronics on the car to tell them when the had a tire going down!
So every thing I have come to is the currant F1 chassis has almost zero flex and the susepnsion and tires do all the work.
Old 03-27-2006, 07:33 PM   #2369
Csaari77's Avatar
Trader Rating: 34 (100%+)
Default Jordan decals
Does anyone know where to get Jordan decals. I want to do a body, and I can't find anything.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 03-27-2006, 09:46 PM   #2370
Click on MLP Motorsports!
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
