Old 12-22-2005, 01:13 AM   #2281
imjonah's Avatar
Default Quick question
Why do touring cars still have a slight advantage lap time wise over F1 cars?
imjonah is offline   Reply With Quote
Old 12-22-2005, 02:04 AM   #2282
SpeedTech's Avatar
I think tires is one of the key reason. There are much more choices and better compound for touring cars than there are for F201. I tried my F201 one time with touring car tires on (it was ugly...) however, just with that one simple change I was able to keep up with most touring cars on the track that day with similar motor power.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 12-22-2005, 03:47 AM   #2283
Formula1fan's Avatar
What traction compound do you guys use on carpet?
Formula1fan is offline   Reply With Quote
Old 12-22-2005, 05:09 AM   #2284
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
If you are planing on comeing to the TCS race at Trackside, Jack the Gripper is the only tire sauce allowed.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 12-22-2005, 08:18 PM   #2285
NIce logo
Old 12-22-2005, 08:40 PM   #2286
f1larry's Avatar
Yours is not so bad as well.
Old 12-24-2005, 09:50 AM   #2287
hpipro321's Avatar
Steve Wang
I agree with you steve, f201 needs more competetive tires than just a's and b's...yes they look scale but they dont serve the purpose to go fast( wining the race) maybe tamiya could think about making more race friendly instead of scale friendly tires
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 12-24-2005, 11:47 AM   #2288
Marty Peterson's Avatar
HI, MLP Motorsports Int ( www.mlpmotorsports.net ) Is making a new Body For the F201 if you didn't see the post's and we will also be offering 3 belted slick rubber tire compounds as well as a set of Foams also by Spring along with a New F2006 F1 2WD Car and Later in the year a 4WD Belt Car and Nitro 2WD Car.
The Body and Tires are for these cars we are making but the same wheelbase and mounting as the F201.
The Body will look just like the bodies F1 ran last year (2005).
The tires will be Front 32mm wide with a 26mm patch and the Rear will be 40mm wide with a 38mm patch.
Happy Holiday's
Here for the fun of it!
Selling HPI F10 Front Knuckles and Complete Rear Axles W/Diffs Ball and Gear.
W/12mm TC Hubs & W/14mm F1 Hubs Good for std bearing Pans cars. STD Bearings!
eBay item number: 200947192161,200947193175,200947187493
Marty Peterson is offline   Reply With Quote
Old 01-01-2006, 08:59 AM   #2289
What is the IR of the F201
Old 01-01-2006, 09:50 AM   #2290
SpeedTech's Avatar
2.6 I believe
Steve Wang
Old 01-01-2006, 04:55 PM   #2291
RCDEMON1's Avatar
Default tamiya f1o2
all you f102 racers need to check out MLP MOTORSPORTS. marty has all sorts of hop ups. and knows the cars. http://www.mlpmotorsports.net
RCDEMON1 is offline   Reply With Quote
Old 01-01-2006, 05:30 PM   #2292
His stuff is top notch! I will be making an order after the TCS.
Old 01-01-2006, 08:51 PM   #2293
hi! I recently purchased an F201. Out of the box, it felt like it lacked some top end. Is it the "super stock" Tamiya motor or can I make adjustments to the pinion?? the 20T pinion is installed now. What is the internal ratio of the F201? thanks!
whirlydick is offline   Reply With Quote
Old 01-01-2006, 09:30 PM   #2294
High Spead Gear set is 52/23
2.6 to 1
For example: Kit spur = 55T Kit pinion = 20T Internal ratio on F201 = 2.6 55/20=2.75 2.75*2.6=7.15 expressed as a ratio: 7.15:1 I hope that helps.
Old 01-07-2006, 11:35 PM   #2295
Lets see pics of your custom F201s! Anyone with cutom painted designs let's see it.
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
