F201
#2221
Originally Posted by Balugz
Speedtech: Do you have any info regarding Tamiya latest 1/10 pan car kit? Will Tamiya support this as racing kit (hop-ups to follow) or simply for collectors? Thanks!
This one looks more like the first kit I had back in 1992
#2222
Originally Posted by ford_racing
is there any way to get more low speed steering, other than adjusting the servo endpoints?
Ferrari body running s3003 servo and KO EX11 Presto radio
#2223
its a beautiful car on the carpet, handles very nicely, just a pain when you get off line in the slow corners and have to change direction very quickly
it requires about 2 laps to get the tyres upto temperature but after that it is absolutely wonderful to drive
maybe i will have to look at the toe settings of the car
#2227
sure is like that
Monaro with his EVO3SE and me with my TB02
his F201 Tuned chassis and now your old Bling Tuned Chassis, though I was using a BMW Williams body just to confuse the spectators, Monaro also uses the BMW, and I now know who the Mark Webber of RC cars is,
everytime I got a clean move on him he would brake late and spin me out, just waited for the immenant mistake and won
#2228
Hahaha, sounds like fun. I think that there is still going to be one guy from our club heading up for the ACT titles, Peter Sprenger (5th in our championship) but that's all I think. Unfortunately this battery saga has put off many of our runners who are now thinking of going to the Winterchamps re-run as well as TCS later in the year rather then the ACT Titles.
#2229
Run the BMW body, and a faster servo both will dramatically improve the quality of the steering.
Play with amount of toe and camber. I generally started with 3 toe 3 camber on the rear, and 2 and -2 on the front. Should give you tons of steering.
#2231
setup
Hey Guys,
Need some setup for a medium grip asphalt track (parking lot).
Thanks, aprreciated any suggestions.
#2232
Originally Posted by f2000racer
Hey Guys,
Ride height no less than 5 mm
Springs soft
Shock Oil 50 3 hole piston if you have the hop up ones )
2 degres camber ( get the pillow ball setting first and adjust on a setup system )
1 1/2 degrees toe in
Semi-tight diff
Top pillow gap 3.5 mm
Bottom: around 4.25 mm
Rear:
Ride height no less than 5 mm just a litle highr than front
Springs Med
Shock Oil 60
2 degrees toe in
tight diff
Top pillow gap 3.8 mm
Bottom: around 4.4 mm
Body: Rear wing position set for downforce
Start with a type tires and if it egts hot switch to B's
Start with stock gearing, Run a 4 minute practice session and if the motor is cool to touch then switch to high speed gear set,
#2233
body characteristics
i know its already been discussed on this thread about the differences between williams vs type-a/ferrari bodies... but i was wondering if anyone notices differences in handling between the type-a and the ferrari bodies?
#2234
Bodys, about the same, the front wing make the difference.
