Old 05-12-2005, 08:51 PM   #2206
quantum's Avatar
thanks for the feedback guys
also wondering - how different is the performance between the 3racing graphite chassis, versus a fully TCS legal chassis??
slightly different? drastically different? X tenths of a second difference per lap?
quantum is offline   Reply With Quote
Old 05-12-2005, 09:09 PM   #2207
Mr. Postman's Avatar
Send a message via AIM to Mr. Postman
I've only run the stock chassis (TCS legal), but I would think that the 3R graphite would give you more of an advantage. With running the stock chassic, you have a choice of only 2 gear ratios (stock and Hi-speed gear sets). I believe the 3R chassis has an adjustable motor mount, so you would be free to gear it as needed.
TC
CoBroRa/TAOB
Mr. Postman is offline   Reply With Quote
Old 05-13-2005, 01:22 AM   #2208
f2000racer's Avatar
Default Type A and B tire difference
Can anybody tell me which one is soft and which one is hard compound, A or B???
Thanks.
f2000racer is offline   Reply With Quote
Old 05-13-2005, 02:30 AM   #2209
Balugz's Avatar
Trader Rating: 16 (100%+)
Default F103?
Speedtech: Do you have any info regarding Tamiya latest 1/10 pan car kit? Will Tamiya support this as racing kit (hop-ups to follow) or simply for collectors? Thanks!
Balugz is offline   Reply With Quote
Old 05-13-2005, 06:52 AM   #2210
fathead's Avatar
Default Re: Re: Re: Re: outdoor
Originally posted by Nova F1 Racer
Remember bump steering is a killer on this car UNLESS you have a pair of the pic attached..... Not TCS legal but when you set your car down it the bump-steering-problem is gone....
Go here to get them....
http://www.gadgetworks.biz/Default.a...ProductID=1934
The only way to change the bumpsteer is to change the height of either the inner or outter ballstud, a bent rod by itself won't do anything.
It didn't say anything on the site about changing the ballstud heights but it may in some instructions that come with the arms, I don't know.
The way I fixed the bumpsteer on my car is to put a couple washers under the ballstuds on the bellcrank and change the ballstuds on the hubs so that they point downwards instead of upwards, I also had to bend the steering arms to clear the suspension arms.
Slavich Design
fathead is online now   Reply With Quote
Old 05-13-2005, 07:52 AM   #2211
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
No flex in chassis, once you set it up i stays...
Plastic tends to bend/etc....
on the same track in MD lap times with TCS chassis 24 secs,
3R chassis was 22 secs,
Why, better design, parts actual fit like they are suppose to, the screws stay tight and the screw holes do not wear out.
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 05-13-2005, 07:52 AM   #2212
Default Re: Type A and B tire difference
Thanks.
Check the sidewalls... Bs is softer
RC Tech member #11
Old 05-13-2005, 07:56 AM   #2213
Default Re: Re: Re: Re: Re: outdoor
Hope this clears it up a little..
When you set the car down and then pres it down the toe in on the front changes. When racing this also happens and some times it make the car hard to rive. The the bent rods this problem is gone "IF" you take the time and set it up right. I also have the stuts on the bottom of the knuckle....
RC Tech member #11
Old 05-13-2005, 08:18 AM   #2214
Neil Rabara's Avatar
Default Re: Re: Type A and B tire difference
The other way around nova. A's are softer.
Neil Rabara is offline   Reply With Quote
Old 05-13-2005, 08:20 AM   #2215
Check your rules in your regional TCS nationals. Here in the states, we are not allowed to alter the geometry of the car.
Old 05-13-2005, 11:43 AM   #2216
Default Re: Re: Re: Type A and B tire difference
Oops... My memory is not what it used to be...
RC Tech member #11
Old 05-13-2005, 02:35 PM   #2217
f2000racer's Avatar
Default Re: F103?
Do you have the right pic??? Coz it looks exactly as my very first r/c car.
Old 05-31-2005, 07:27 PM   #2218
lbckevin's Avatar
Trader Rating: 91 (99%+)
Time to break out the F201's for this weekend.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 05-31-2005, 08:23 PM   #2219
KiwiKid's Avatar
It is a re-release I think.
KiwiKid is offline   Reply With Quote
Old 06-30-2005, 11:05 PM   #2220
ford_racing's Avatar
Send a message via MSN to ford_racing
is there any way to get more low speed steering, other than adjusting the servo endpoints?
Ferrari body running s3003 servo and KO EX11 Presto radio
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
