Old 09-21-2004, 10:04 AM   #1861
psycho's Avatar
Neil Rabara
I tried A's all around with their normal insert and I had way too much steering. I tend to set my cars up very trimmed out normally and it was pretty tough to keep ahold of with A's up front. That's why I went with Pit Meds up front. The track I was at was pretty green, since no one was running foams the whole day. You typically don't overheat tires on carpet, so I don't think having an airgap would be particularly advantageous. I've had that car working well on the same track with Pit Meds all around and I think that would be faster, but I didn't feel like making drastic setup changes to the car.
psycho is offline   Reply With Quote
Old 09-21-2004, 05:46 PM   #1862
ChrisP's Avatar
Is there anyplace that has the F201 Full Option yet that was on the RCCA Lust List???
All I can find are the basic kits, and even those seem to be pretty rare
ChrisP is online now   Reply With Quote
Old 09-21-2004, 06:39 PM   #1863
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
here are a couple kits on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...922364809&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...922275086&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...922275079&rd=1
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is online now   Reply With Quote
Old 09-21-2004, 07:54 PM   #1864
danjoy25's Avatar
Trader Rating: 37 (100%+)
I have a fully optioned (all tamiya Hotup included) that I might sell within 2 weeks. Send me an email with an offer.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 09-21-2004, 10:56 PM   #1865
Neil Rabara's Avatar
Originally posted by psycho
Neil Rabara
I wouldn't run an air gap on carpet. Too much traction with too much sidewall flex. Thanks for the input.
Neil Rabara is offline   Reply With Quote
Old 09-22-2004, 10:34 AM   #1866
lbckevin's Avatar
Trader Rating: 91 (99%+)
I had to sell my non tcs car because, I need the money for my bills ......
Kevin
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 09-23-2004, 11:53 AM   #1867
Kevin, why are you selling that stuff? F1RL remember?
Old 09-23-2004, 12:49 PM   #1868
mikejr718's Avatar
Send a message via ICQ to mikejr718
Default f201 carpet set-up advice
I am looking for info on setting up my f201 for indoor carpet racing. I have the type A tires already. Wondering about camber,rear toe,shock oil and springs,etc. I have been thru previous posts and have not been able to find anything.
mikejr718 is offline   Reply With Quote
Old 09-23-2004, 12:53 PM   #1869
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Everything is different for every driver so I would suggest running the kit settings as per the manual and adjust everything from there to your likeing. Just don't use the stabilizer bar, hahaha. Also, what motor are you going to be using??
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 09-23-2004, 01:28 PM   #1870
mikejr718's Avatar
We are running the trinity street spec motor at the track I race at. We have been running the high speed gear set but the layout recently changed from a fast flowing track to a tighter layout. Last weekend during practice one f1 car had its motor leads come unsoldered so I suspect that with the tighter layout that I will have to switch to the kit gear set. I read the article written by Neil on Tamiya's web site and tried that set-up on carpet and the car felt terrible. I previously had been running the kit set-up with some sucess.
Old 09-23-2004, 03:27 PM   #1871
psycho's Avatar
mikejr718
Yeah, Neil's setup is for asphalt, so that won't work very well on carpet. Here's a basic setup that should point you in the right direction. I don't race my F201s on carpet all that often, but this should help you keep the car going in the right direction and you can fine tune for your particular track. I was running pretty close to this over the weekend on carpet. I have a lot of non-Tamiya stuff on my car that will be hard to find, so I am translating some things to equivalent Tamiya stuff. Since you didn't mention anything about TCS, I'll assume you aren't concerned about keeping the car TCS legal.
Front:
* Pit Shimizu medium tire with included insert
* 5mm ride height.
* Track width set to 190mm
* 1.5 deg negative camber
* 0.5 deg toe-out
* Tamiya alum shock bodies, 3 hole piston, 40 weight Trinity shock oil, one extra black o-ring over the shock shafts before assembly. If you use the plastic shock bodies and the previously mentioned piston, use 50 weight Trinity oil.
* Tamiya gold spring
Rear:
* Tamiya Type A tire with included insert
* 5mm ride height
* 3 deg toe-in
* Wing set to minimum downforce position
If the backend is loose, use your radio's dualrate to tame the car down. You should have plenty of steering with this setup. Once you get the car working well, you should be able to go with medium Pit Shimizu tires all around and make the car faster. imo, Type A's are just too soft for carpet and they really slow the car down.
Old 09-23-2004, 03:31 PM   #1872
mikejr718's Avatar
Thanks for the info-will try it this weekend.
Old 09-23-2004, 06:29 PM   #1873
Hence my disclaimer. Carpet is a whole new thing to me, If I had something to offer, I would.
Old 09-23-2004, 10:03 PM   #1874
danjoy25's Avatar
So far Neil's setup is working with abit of adjustment. This will be the layout for the Australian TCS. Its a concrete track.
Old 09-23-2004, 10:20 PM   #1875
Yes unfortunately concrete, with added dirt, jumps (Biiger than bumps lol) and dog hair (also a dog show pavilion).
It has made things very interesting trying to get a setup. I have been able to get the car around well, but everytime i drive someone elses car it feels like i could go a lap faster. lol
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
