F201
#1547
That's a month earlier than last year. I wonder why?
#1548
Tire Adaptors
Does anyone know if someone makes tire adaptors for older HPI F1 kits and/or Cross kits so that they can use Tamiya Rubber F1 tires?
We are attempting to start spec class and there is a question from people who have older models who want to race in the class but are afraid they will not be able to comply with the tire rule.
Are the their adaptors for these other kits to use Tamiya Tires/Rims?
#1550
Re: Antenna Mount on Cross Chassis
Originally posted by Runin Ronin
I just bought a F201 from a forum member. It has the Cross chassis... Does anyone have a picture on how the antenna is mounted with this chassis?
Thank you,
John
Thank you,
John
#1551
You can use any antenna mount. I use a Xray mount.
#1552
#1553
Originally posted by Nova F1 Racer
Yep..... Neil has to be different...
#1556
That would make more sense instead of Oct.
#1557
blank setup sheet?
hey all
anyone know where i can get a blank setup sheet for F201 chassis?
#1558
Re: blank setup sheet?
Originally posted by quantum
hey all
hey all
I made one and it wasput up on www.formula1-rc.com
There is 3 of them there.....
http://www.formula1-rc.com/Default.aspx?tabid=103
#1559
Battery slop
I just finished installing my 3 Racing graphite chassis. There is a lot of slop when using stick packs. What has anybody done to eliminate this? Side by side packs fit tight but I worry about shorting the cells on the standoffs, motor plate, or gear support.
#1560
There are some things you can do. Double sided tape on the chassis, or just protect the batts from shorting by covering up the metal supports.
