Old 05-20-2005, 04:07 PM   #1
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Pros & Cons of Step Charging
Just got a new charger and is really interested to know more about step charging. Would this give me more runtime/punch? Any info would be good.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-20-2005, 06:24 PM   #2
Default Re: Pros & Cons of Step Charging
no good for 19 and stock racing way to flat NO PUNCH
lickrim is offline   Reply With Quote
Old 05-20-2005, 06:27 PM   #3
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
I use it for everything, I find it better in all areas, run time, punch and voltage.
Chris.
crimson eagle is offline   Reply With Quote
Old 05-20-2005, 06:30 PM   #4
Chris.
you run 4 cell stock in a pan car dude ...everything has punch when it comes to 12th scale ...power to weight ratio?
Old 05-20-2005, 06:34 PM   #5
Send a message via AIM to micros_rock
If you are running mod, then step-charging is fine. Stick with a linear charge for stock though.
micros_rock is offline   Reply With Quote
Old 05-20-2005, 07:07 PM   #6
wothrottle's Avatar
step charging is only a marketing gag, there are no real benefits from it. stay with linear charge!
wothrottle is offline   Reply With Quote
Old 05-20-2005, 07:09 PM   #7
My results, on and off the track confirm that step charging is better accross the board than linear. This is not just my opinion, I have done the tests and have the numbers. You can take my word for it or not thats fine. If you are not seeing the same thing then that is fine, however my opinion is just as valid as yours, I will not say that your opinion is wrong, just extend me the same courtesy if you don't mind.
Chris
Old 05-20-2005, 07:24 PM   #8
ottoman's Avatar
Chris... what steps (settings) do you charge at?
ottoman is offline   Reply With Quote
Old 05-20-2005, 07:34 PM   #9
hey dude 19 ,stock you need all the punch you can step charging takes that right out of the picture..i use trays and dead short all my packs,chargem at 10 amps too...thats how you make big power for touring ... its cool homie
Old 05-20-2005, 08:07 PM   #10
you probably buy new cells every two months as well, you can only abuse cells like that for so long before they die.
I use 5/7/5 amps with the first and last phases linear and the center phase a 30% hard pulse.
Old 05-20-2005, 08:22 PM   #11
i dont buy my cells your right , thats how you make big power...dont buy your batts... and get some free packs
Old 05-20-2005, 08:32 PM   #12
Chris don't waste your time on LICKRIM...the name says it all. Charging at 10amps is lame. There is not much power gain from 7 to 10 amps been there done that? Chris has done his homework and if you want to learn something check the PROTRAK thread.
thx Charlie
I post my name
gotyournumber is offline   Reply With Quote
Old 05-20-2005, 08:36 PM   #13
oh really , i did this with brand new cells last year the RROC and got third overall in open spec, your only as good as your last race homie .....keyboard racing ( your the fastest one so far)
CHARLIE "ALL BITTER' ALBRECHT
Old 05-20-2005, 09:16 PM   #14
dakrat's Avatar
agree! charging at 10 amps is lame.
dakrat is offline   Reply With Quote
Old 05-20-2005, 09:23 PM   #15
AHHH WERE YOU AT THE REEDY YOU ONLY CLUB RACE HEY HOMIE THATS HOW WE DO IT IN CALI
Pros/Cons on AE 18R Huffpie Micro and Mini Scales 5 12-07-2008 07:11 PM
pros and cons _nick_ Electric Off-Road 6 02-28-2006 08:03 AM
Pros and Cons! Bobby J Electric On-Road 6 01-06-2005 07:15 AM
pros and cons of XXX-S & TC3 jiggamacdaddy Electric On-Road 15 04-30-2003 10:09 AM
pros and cons on the v-one rr fuse01 Singapore R/C Racers 16 04-05-2002 01:39 AM
