Old 05-19-2005, 02:37 PM   #1
acutts's Avatar
Default Servo problem?
I have just finished building my T1FK05 and I have installed a ko 2343 Servo and when I turn all the gear on it makes a load buzzing noise when turned all the time .. is this correct or have I done something worng?
acutts is offline   Reply With Quote
Old 05-19-2005, 02:49 PM   #2
tc3blue's Avatar
If it always makes a loud noise there's definitely something wrong, but make sure that nothing's binding and that you can move the wheels freely; also make sure the servo is neutral.
Servos usually make a noise when for example you can't turn the wheels any more (by hand) but the servo still tries to turn them and this is when you reduce the max left/right endpoint or lower the dual rate.
tc3blue is offline   Reply With Quote
Old 05-19-2005, 02:57 PM   #3
scoobydo's Avatar
Default Re: Servo problem?
The new KO servos require a higher BEC and has some trouble with certain speedos.
If you are using a Quantum Comp 2 speedo, then the new KO will not work. I even tried installing a cap and still could not get it to work.
I had to go back to using my KO 2143 and it works fine.
Does the servo work fine, it just makes a noise?
Because mine would not work at all and when it did, it would not be responsive to the Trasmitter. It would lag and jerk around.
scoobydo is offline   Reply With Quote
Old 05-19-2005, 04:24 PM   #4
DT-Skyline's Avatar
Send a message via AIM to DT-Skyline Send a message via Yahoo to DT-Skyline Send a message via Skype™ to DT-Skyline
Ok. If it's lik that , it's probably either the gears or its mayb a defect. Or, as Scoob was sayin, it could also be the ESC.
DT-Skyline is offline   Reply With Quote
Old 05-20-2005, 01:26 AM   #5
acutts's Avatar
Default Re: Re: Servo problem?
Hi
I did have it installed with a Quantum 2 speedo so maybe I will try it with my new Hara twister 2 ..! I was using this servo before with a nosram evo speedo and it was fine. It doesn't buzz when in neutral just when I turn either left or right? When I disconnect it from the steering mechanism then it doesn't make any buzzing sounds at all???
I am really stumped... :-(
Regards
Scott
SERVO PROBLEM lancerevo22194 Micro and Mini Scales 11 07-23-2008 04:17 PM
ESC or SERVO Problem kimbalion7 Electric On-Road 4 02-02-2006 04:27 AM
servo problem. Please help! cars.cars.cars Nitro On-Road 4 08-22-2005 01:02 AM
servo problem wothrottle Electric On-Road 0 09-29-2004 06:24 AM
servo problem wahturi Nitro On-Road 7 12-25-2002 10:48 AM
