Question on Take-Offs and others
On the Take-Offs how do you know what insert you are getting?
I have some that have blistered and grooved the inside edge and others havent on the same night and using the same setup. We have come up with some of the inserts are softer than others so how do you know if you are getting soft, medium, hard, etc? |
Re: Question on Take-Offs and others
Originally posted by new92 On the Take-Offs how do you know what insert you are getting? I have some that have blistered and grooved the inside edge and others havent on the same night and using the same setup. We have come up with some of the inserts are softer than others so how do you know if you are getting soft, medium, hard, etc? |
You don't have any way of knowing and you are not the only one havin this issue. I think I'm going to start gluein mine up. I have my one sedan on brand new Take Off 27's premounts and the other on Sorex 32R's self glued. I raced both last Saturday and the Take Offs are already starting to show that groove on the inside. I'm thinkin the inserts are pretty much crap now that I have tried good inserts with good tires. I may need to get a set of 27's with good inserts and glue them up to see how they wear.
Originally posted by new92 On the Take-Offs how do you know what insert you are getting? I have some that have blistered and grooved the inside edge and others havent on the same night and using the same setup. We have come up with some of the inserts are softer than others so how do you know if you are getting soft, medium, hard, etc? Like paul also said the inserts in all cs premounts are medium. I did cut some open when they first came out to see. Just remember suspension tuning includes seting up for tire wear!!:cool: |
Just try them with Yok firm inserts...they always work
yeah yoke038 inserts are good along with hara greys and hpi yellows or orange, me presonally i like 26mm dish rims with a take off 22's or 27's with hara grey inserts, works real good on the tracks over here in the uk and in most temp ranges and the wear is pretty even, and thats with running 1/2 degrees camber all round.
hope that helps you a little? you may wanna see what the guys at your track are running if they are not premounts:D J-P |
