Old 05-25-2005, 10:28 PM   #16
scoobydo's Avatar
I'm sorry. $519 for an unproven radio? Dude current top of the line 3 channel radios are $350-$400 MAX
I'll pass and wait for all the bugs to be worked out before I spend 1/2 a grand on a radio.
scoobydo is offline   Reply With Quote
Old 05-25-2005, 11:54 PM   #17
Send a message via AIM to WhoMe
I think he knows how much the top crop costs..he said he had a 3PK. And its not untested, Ive been on the testing team for months. Congrats on your purchase. I also found the spring tension alittle stiff at first but Ive grown accustomed to it. Asfar as support is concerned Id try emailing them..and or the RCCA thread..or the Nomadio thread on RCUniverse. Roy has been fielding questions on both forums.
WhoMe is offline   Reply With Quote
Old 05-26-2005, 01:45 AM   #18
Originally Posted by clmbia45
An interesting little fact: in contrast to my Futaba 3PK (you can apply power to the receiver, but it does not power the servos until the transmitter is turned on) the Sensor powers the servos as soon as the receiver is powered, even with the transmitter off.
With the 3PK and spektrum module, if you power the RX on first, the radio goes straight to fail safe... servos move to their assigned positions..
Then when you turn the TX on the radio connects up and you have control...
A side effect of this is with momentary power loss... it causes the RX to go to fail safe until it reaquires the new signal...
Galifrey is offline   Reply With Quote
Old 05-26-2005, 02:01 PM   #19
ddesros2's Avatar
To anyone with the Nomadio system:
When you have a chance can you take a couple pics of the radio powered up and the RX installed in a car? Thanks.
ddesros2 is offline   Reply With Quote
Old 05-26-2005, 06:00 PM   #20
Send a message via AIM to rcguy2477
RCGUY:
The receptacle on the car transceiver is three lead with no polarity marked. The male connector has the positive wire in the middle. Are both end positions negative?
I assume you are talking about the voltage sensor?
I believe both outsitde ones are negative, and the positive in the center. In the manual they may warn about plugging it in backwards, but it is impossible using the included connector
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 05-26-2005, 09:04 PM   #21
clmbia45's Avatar
Cool
VERY interesting! Checked the Sensor, and the failsafe was on "SET". Moved it to "HOLD" and same thing occured. Reviewed the manual, and I don't see any way to turn "Failsafe" off. In a sense, placing it in "hold" position is the same as turning it off.
It apparently is responding to an absense of transmitter signal. I didn't find any indication of a low voltage trigger, but this would be redundant with the voice/vibrator wasrning system.
clmbia45 is offline   Reply With Quote
Old 05-27-2005, 07:15 AM   #22
nomadio's Avatar
Jack,
We are setting up a support message board at www.nomadio.net. Should be ready by end of next week. That will be our focus point for customer support and downloads.
To answer your questions:
The 4 conductor mystery connector is used to update the software in the Transciever should that need to happen in the future. The connector mates with a programming connector on the reciever.
There are blocking diodes on the battery connector- if you put it in wrong, nothing bad happens, but it won't power up. The manual is being updated to reflect this. We view the manual for this product as a living document and will be updating it regularly.
We're working on the install routine - the USB driver generates a warning in some XP and W2K systems but it is really not a meaningful warning. It has to do with the fact that the USB driver wasn't run through Microsoft's $$$ testing lab. It's the only general purpose USB driver we could find.
Roy
Nomadio
nomadio is offline   Reply With Quote
Old 05-27-2005, 07:23 AM   #23
jeffreylin's Avatar
R/C Tech Charter Subscriber
Will it work on a Mac?
jeffreylin is offline   Reply With Quote
Old 05-27-2005, 09:04 AM   #24
nomadio's Avatar
Jeffrey,
Sorry, PC only. : (
Roy
Old 05-31-2005, 09:29 AM   #25
Lightbulb Nomadio Support Forum
Nomadio now has an official support forum available at:
http://support.nomadio.net/ . Feel free to post any questions you have about the Sensor or Nomadio there. Thanks!
-Dave Acker, Nomadio
Nomadio_Ack is offline   Reply With Quote
Old 11-23-2005, 03:46 PM   #26
nomadio's Avatar
Default Big News from Nomadio
Hey,
Just thought you guys might like an advance look at the big announcement we're making on friday. Check out
http://blackfriday.nomadio.net
Cheers,
Roy
Nomadio
Old 02-28-2006, 05:58 PM   #27
Lou Decruss's Avatar
I hear Nomadio is going to have a program that lets the Sensor talk to spektrum receivers
LOW / SLOW mode LOW as in they have to go to low power by a FACTOR OF 6, slow because we have to go from 100Hz to 50Hz
DAMN!!!
Lou Decruss is offline   Reply With Quote
Old 03-03-2006, 10:56 AM   #28
the pig's Avatar
Send a message via Yahoo to the pig
new download coming before day is over so be ready nomadio users. even better everyday.
the pig is offline   Reply With Quote
Old 03-07-2006, 02:16 PM   #29
the pig's Avatar
nomadio will be putting out new update. these guy's are thinking sensor thoughts from all of youu and this and more is what they love to do is customize all for the driver. if you are thinking and not sure call them and tell them that. they will take your info and send you a sensor so you can trial it and if your not send it back in for no cost to you. now who else is willing to do this? have fun, drive fast!
Old 03-07-2006, 05:11 PM   #30
stonedgti's Avatar
Trader Rating: 15 (100%+)
There is no reason for you to post the same content on 3 different threads.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Nomadio Sensor REVX R/C Items: For Sale/Trade 16 05-03-2008 01:46 PM
w.t.t. nomadio sensor for a nomadio react xtreameracer R/C Items: For Sale/Trade 4 12-07-2007 07:36 PM
Nomadio Sensor/transciever and sensor pack DaveH R/C Items: For Sale/Trade 14 05-14-2007 11:12 PM
nomadio sensor snaponguy R/C Items: Wanted to Buy 2 01-29-2007 01:40 PM
Nomadio Sensor, V2 transeiver, temp sensor sstoffer R/C Items: For Sale/Trade 1 01-16-2007 02:35 PM
