Old 05-02-2013, 02:01 PM   #1
Default Futaba 9650 servo
Need to change the case on my 9650 servo how do I remove the motor from the case. Have found the pot is secured by clips and can release them but the motor is a problem.
Anyone done this and can tell me what to do?.
Bosscat is offline   Reply With Quote
Old 05-03-2013, 01:47 PM   #2
Anyone help?...
Old 05-03-2013, 01:52 PM   #3
AdrianM's Avatar
Originally Posted by Bosscat View Post
Anyone help?...
Most servos are the same...if you take all the gears off the case you will see a clip or screws that hold the motor to the case.
Adrian Martinez
Old 05-03-2013, 03:10 PM   #4
Trader Rating: 26 (100%+)
I think you'll find the motor has a smear of silicone holding it in. If you look from the gear side of the case, there should be some slots in the plastic where you can see the metal can of the motor. Use something through these slots to push the motor out. I didn't silicone mine back in and it seems to beholding up fine.
CountryHick is offline   Reply With Quote
