Old 05-20-2013, 08:14 PM   #16
CristianTabush's Avatar
Originally Posted by Skiddins View Post
Hi Cristian (and others who have used the springs)
What combinations have you used on medium/low grip asphalt, both smooth and slightly bumpy.
Currently using the 2.5-2.8 front springs with 2.5 at the rear, but could perhaps do with a little more initial.
Skiddins
It really depends on the feel that you like on the car.
Typically I start with silver/silver all around. If the rear is rotating a little too fast, I go to RSD Pink Carpet. If you want a little more stability Green fronts can help too. This is with medium roll centers.
With what you have right now, try the silver in the front first, with your 2.5 rears. After that, try silver all around. I typically tell people to try them on in the front first and then all around. This allows them to appreciated the qualities the silver springs offer.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-20-2013, 08:16 PM   #17
Originally Posted by Cpt.America View Post
The only issue I have with Reflex Racing, is that it's so dang hard to find what im looking for on their website (maybe what im looking for isn't available anymore?). All I want is a pair of normal Silver and Blue TC springs.. can't find them (all I can find a new black springs, that run different colors... looking for the same, non-coated reflex springs that I got late last year)
Anybody have a link?
(and yes... reflex is good stuff)
Hey Brandon, unfortunately those springs are discontinued because the factory went out of business. You might want to try superior hobbies to see if they have any left in stock. Otherwise, your best bet is to try the new Green Springs, they are actually in between the silver and blue. Same wire size, so they should behave very similarly.
Old 05-21-2013, 01:29 AM   #18
Typeone's Avatar
Trader Rating: 30 (100%+)
Hey Cristian my names Tim I placed an order #RX7162 which included stickers, shock o-rings, shock bladders and aluminum fan mount for tc6. I'm just wondering cause I ordered the spool cups, pistions and 3 racing camber plates thats i recieved first before my other order. Thanks please let me know if possible can u give me a call at (559)307-9279 or email me at [email protected]. Thanks again.
Typeone is offline   Reply With Quote
Old 05-21-2013, 03:16 AM   #19
Skiddins's Avatar
What would you recommend I try on a fairly tight indoor carpet track, currently 2.7F, 2.5R and if grip comes up enough 2.7r;
+ YouTube Video
It's 13.5 boosted, so brakes are used a little.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-21-2013, 10:52 AM   #20
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I run more carpet than asphalt and I have been really fine tuning my spring choice in similar conditions except I have been running Mod. Based on what you're running now you could start with a carpet blue rear and a carpet pink front. At our track (96x40) medium grip with mod I have really liked black rear and blue fronts, 2.3's all around, and 2.3-2.6 progressives all around with either 350 or 424 4 holes 1.1's.
Old 05-21-2013, 11:25 AM   #21
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Great, so I called superiorhobbies, and it looks like they DO, but we are a bit confused because they have different non-coated silvers, with different product numbers, with different weights listed. He said they have the following:
silver 002 13.6lbs
silver 003 14.5lbs
What I want is the same tc6 springs I got last year (running them on my tamiya), blues, silvers, and whatever color is just softer than silvers. Can you guide me to the correct springs so I can tell the guys at superior which ones to drop in the bag for me? (I left you guys a voice mail at your main contact phone#)
-Brandon
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-21-2013, 11:27 AM   #22
Those two are the same spring. The difference is we changed the rating from 14.5 to 13.6 to reflect the real rating of the spring.
Old 05-21-2013, 11:30 AM   #23
Please contact the store at: [email protected] and tell them about your problem. We'll get you taken care of.
Old 05-21-2013, 11:31 AM   #24
Xpress's Avatar
+ YouTube Video
Skiddins
You consider that track "fairly tight?"
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 05-21-2013, 11:32 AM   #25
Damian, start with 4x1.1 pistons with 350 oil, medium roll centers, pink front blue rear.
After that, try blue front/blue rear and then blue front/black rear and compare results.
Pinks are like 2.6, blue are like 2.45 and black is like 2.35
Old 05-21-2013, 11:34 AM   #26
Super Moderator
But I also see:
TC6 13.5lb Spring (YELLOW) Style: RSD002
So there is a 002 silver, and a 002 yellow in the old school spring?
- RCSpecialties -
Old 05-21-2013, 11:36 AM   #27
Skiddins's Avatar
It's currently the smallest track I run at.
I have raced at smaller and tighter but not by a huge amount.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-21-2013, 12:00 PM   #28
Skiddins's Avatar
What's the reason for starting so soft? (by comparison)
I have just fitted the RSD 4 hole 1.1mm pistons and usually run 450 oil with Xray 4 hole 1.1's.
I found that the thicker oil didn't really change the laptimes but did seem to make the car easier to drive more consistently.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-21-2013, 12:15 PM   #29
But I also see:
Ignore the part no. Go by color. It was a running change. The yellow is actually softer than 13.5.
Silver/silver is the same and what you are looking for. Yellow is softer.
Damian, I like to start with softer oul if grip is low and I go up until the car starts getting worse. I basically want to get away with the thickest oil I can get away with, but I have to start soft and go up.
Old 05-21-2013, 12:48 PM   #30
Super Moderator
Thanks Cristian. I went ahead and ordered the following:
Style: RSD002
TC6 14.5lb Spring (SILVER)
Style: RSD003
TC6 15.5lb Spring (BLUE)
Style: RSD004
- RCSpecialties -
