Old 06-16-2005, 12:38 PM   #91
COld freeze spray will only chill the outside of the material, it will not penetrate, unless of course you keep spraying for mebbe 15 minutes...
MartynD is offline   Reply With Quote
Old 06-16-2005, 12:40 PM   #92
rc-zombies's Avatar
probably cost more in the long run......
may have to get me one of these MM motor coolers soon.
Old 06-17-2005, 09:17 AM   #93
Qwiglee's Avatar
I ordered mine from RCModel and apparently they have them in stock because I got a series of emails where the status changed from "processing" to "preparing to ship" to "shipped." Hopefully I will have it in time for the KO Propo race next weekend.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 06-18-2005, 01:22 PM   #94
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by pheyhoe
yeah but the amp draw will kill the punch of the cells.. no?
i wanted one but they are 100 here :S :S roughly translated into dollars....
$170, lotta ,money.
OK LAST TIME.....These are to be used prior to racing (30-60mins) prior to be axact. This will allow the motor to get to very low tempature (all depends on ampbiant temp) and right before you do to tech you take off the cooler and whip off tire compounds.
THESE ARE TO BE CONNECTED TO A 12V Power Supply. Preferably a large one. With a 4.5-5amp draw of power a lower AMP power supply will struggle if you use it for anything else. I bought two Power Supplies one just for battery charging and the other just for accessories.
I hope this clarifies things....
Yes they work great and worth the extra cash...Just by me using them I was able to gear the motor for more power...I only suggest this to guys who know how to geear properly already.
They are small and powerfull. I loved one so much I got a second just for those times i race two classes.
It has become a new Must have item in your pit bag...
Right next to it is the Much More Battery Heatsinks....
They are a whole different treat...
Here is how they are different than a battery cooler.
They help disapate the heat that a battery will accumulate while either chargign or discharging...
Now I am able to charge my packs @ 7 or 8AMP with the pack only getting to 40*C. See my point for all those stock and 19T racers out there..
BRAVO Much More...Keep the goods a comin'.
-Stephen <><
STUFF I HAVE FOR SALE.
http://www.rctech.net/forum/showthread.php?t=75474
http://www.rctech.net/forum/showthread.php?t=75202
http://www.rctech.net/forum/showthread.php?t=75472
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-18-2005, 02:48 PM   #95
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Mr. Shookie,
Cycle one of your batteries without the heatsink and then cycle on with the heatsink....I think you will quite using it after you cycle them that way
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-19-2005, 04:48 PM   #96
s2
s2's Avatar
hmm, these coolers look abit tasty, are they available in black?
Originally Posted by keithander
If you are in the UK, the UK stockists have them now:
uk stockists
Thanks,
Keith.
Keith, when are the MuchMore comm lathes avalibale in the UK and what sort of price?
cheers
stew
s2 is offline   Reply With Quote
Old 06-22-2005, 11:47 PM   #97
RBLove's Avatar
Trader Rating: 72 (100%+)
Any body know if one of these units can be used on the Losi JRX-S? There is pretty large opening in the bottom of the chassis below the motor..
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 06-22-2005, 11:57 PM   #98
danjoy25's Avatar
Trader Rating: 37 (100%+)
If you can use a motor heat sink under the chassis, I don't see a problem.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-23-2005, 12:33 AM   #99
acutts's Avatar
Originally Posted by EAMotorsports
Mr. Shookie,
EA
So are you saying the battery heatsink is something that should not be used?
acutts is offline   Reply With Quote
Old 06-23-2005, 12:44 AM   #100
danjoy25's Avatar
I suppose the heat sink are similar to using a fan while charging as it takes the heat away and might risk damage to cell. I won't even think of charging 7-8 amps.
Old 06-23-2005, 04:46 AM   #101
The thing that people are scared about charging at such a high rate is heat....or too much heat that is. Once you get the right mixture of heat distribution to amp input to get you the exact same tempature as if you didn't use the heat sink and charge at say 6 amps. That way you are not damaging your cells by anyway shape or form. I find that charging at 8amps with the heatsink I get my cells peaking at 45*C and the votage is insane...like numbers holding near 9V after they are finished charging and off the charger. Tell you what in stock and 19T you want as much punch(votage) as you can get. I am going to keep testing but so far so good. Cells seem to discharge great and like the quicker charge. It also only take about 25-28 minutes for a 3700 pack to peak now.
Which also helps when you are in a pinch because you started the charge late.
Just my experiences so far.
I will be your guy's lab rat.
-Stephen <><
Old 06-23-2005, 07:08 AM   #102
RBLove
I have not yet managed to get it to fit through the hole on the bottom of the JRXS chassis (although I have not forced it)
I just take the motor out and a couple of mins before i'm up to race screw the motor back in, mesh and away we go.
Not ideal but it doesn't take long
speedfreakUK is offline   Reply With Quote
Old 06-23-2005, 07:13 AM   #103
Scho's Avatar
Send a message via MSN to Scho
Anyone know of anyone that have these in stock in the UK???
Scho is offline   Reply With Quote
Old 06-23-2005, 07:17 AM   #104
acutts's Avatar
Cleveland models
goto www.much-more.co.uk and go to stockists .... I got mine from them and it is awesome!
Old 06-23-2005, 07:23 AM   #105
Much More will supply direct to your local model shop. Mine arrived within 2 days
FS MuchMore Motor Cooler sig sour R/C Items: For Sale/Trade 1 03-17-2008 04:57 PM
Muchmore Motor Cooler DoH Australia For Sale/Trade 2 12-29-2007 01:13 AM
FS: MuchMore Motor Cooler xxx787 R/C Items: For Sale/Trade 5 12-03-2006 01:06 PM
MUCHMORE motor cooler scottw R/C Items: For Sale/Trade 4 04-06-2006 07:25 AM
WTB MuchMore Motor Cooler erock1331 R/C Items: Wanted to Buy 0 12-13-2005 05:59 PM
