Testing On MuchMore CTX-TM Motor Cooler
#181
Originally Posted by erock1331
I was hoping somebody could give me a direct link to a fan that would work, lol
cause i am clueless
cause i am clueless
Is there no spec on either the Much More fan or the one that radio shack had? normally there's a sticker on either side to give you an idea of the specifications, that way you can enquire about a sample possibly from one of the company links I gave you.
You know what the peltia unit does, so explain that to the companies and ask there advice on which fan they would advise to use, bearing in mind you are after a sample, so be shrude I was
Malc TCCFM
#182
i'll tear it apart again, the only thing I remember seeing the first time around was a much more sticker on the fan. but maybe if i take that sticker off i will find something under it or something else enscribed on the fan elsewhere
#183
u know if you damage it, if it doesnt get hot on the top side anymore then its broken. if the peltier gets above around 50c then they fry themselves.
#184
I tore it apart again, the only thing it says on the fan is Much More 12v DC
No other specs or part numbers
#185
Hope this helps
Malc TCCFM
#186
well the radio shack one is
5000RPM
10CFM airflow
130mA
and they say its not that powerful so i guess i need something stronger
5000RPM
10CFM airflow
130mA
#187
The fan is 50 mm x 50 mm, which you will find out isn't the easiest fan size to find.
#188
CCFM
#189
I did find a fan online at COFAN USA that was a 50mm x 50mm and it put out 17.1 CFM at 5500 RPM which seems to be almost double the output of the radio shack one. Bad part is no order info or price so I might call them tomorrow.
Most other CPU fans 50 x 50 mm that I found online are less than the radio shack one only putting out like 8-9 CFM
#191
Thanks Jeff.
I ended up ordering that one. I will post back and let everyone know how it works
#192
I'm about to buy one of these, and after reading almost the whole thread (probably should have read every page)... i have just one question.
would this MM unit work on the motor better if the sticker on the motor can is removed? (peel off the motor can sticker for better contact with the cooler device?
curious.
Thanks, James
curious.
Thanks, James
#194
Fan spec.
Hi all,
The spec. of fan come with Motor cooler is
12V
12,000RPM
Two ball bearings.
The model is specially ordered by MuchMore, maybe it is hard to get
one from market.
Muchmore USA will service it, please contact.
www.teammuchmore.com
> James Kim
Thanks,
Ryan Lee/MuchMore
12V
12,000RPM
Two ball bearings.
one from market.
> James Kim
Thanks,
Ryan Lee/MuchMore
#195
Ryan Lee
If I just send the fan back will muchmore replace it?
I have replaced my fan with a less powerful one that seems to be doing the job for now but i really would like to have the original fan.
I dont wanna have the whole unit gone for too long so I just wanted to send back the fan.
