Old 01-03-2006, 01:26 PM   #166
Anyone know how to get a replacement fan ?
I was using my cooler and here my pit towel got caught in the fan and burned the fan up.
I think the unit still works hopefully otherwise, but it did get super hot.
Does anyone know if I can send the unit back to anyone to get it fixed or if I can just get a replacement fan from either Much more or from an electronics shop ?
I have a pretty good shop by me called Philcap who usually stocks alot of fans like that. Also I think radio shack has fans, but I have no clue if they would be the right application.
any help is appreciated.,
erock1331 is offline   Reply With Quote
Old 01-03-2006, 01:28 PM   #167
Originally Posted by AdrianM
Guys this is impressive and all but you really don't want to freeze you motor before a race. If you get it to just above 0 deg C you are perfect. If you get it colder to the point where it is frosting up you can actually freeze the arm to the magnets and stall/short out your motor, gum up the oil in the bushing/bearings, etc.
What ever you do make sure you motor will rotate before you pull the trigger. on your radio.
I agree, I froze mine down to under 28 deg F and then added some freeze spray after taking it off the cooler and my car was on the line for an oval race and it never moved when the bell rang. A guy manually gave the wheels a bump and it finally turned the motor over.
Now I know next time not to over freeze it
Old 01-03-2006, 01:46 PM   #168
Trader Rating: 14 (100%+)
Send a message via MSN to BigJim14226
can anyone design one for these for a can of BEER ?
BigJim14226 is offline   Reply With Quote
Old 01-03-2006, 01:52 PM   #169
gee-dub's Avatar
attached are a pic of my friends motor cooler. no problems with arm freeze-locking (yet).
Testing On MuchMore CTX-TM Motor Cooler-mc01.jpg   Testing On MuchMore CTX-TM Motor Cooler-mc02.jpg
gee-dub is offline   Reply With Quote
Old 01-03-2006, 02:05 PM   #170
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
I'm not too sure why but every unit seems to vary, even in the same place in the room, at the same time, for the same amount of time.
We did a test with a few in the same place for the same amount of time. Most reached about the 1-2*C(not sure what faranheit) 1 was very poor at 4.5*C and one reached -1*C. The guy's that reached -1 is just incredible, he hasn't played with it any way, it'll just freeze itself to anything near it! Leave it on your pit towel for a short amount of time and next thing your doing is figuring out how to remove it! Yesterday it froze itself to the motor can he regurlarly has to pick ice off it. It seems some peoples are beter than others
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 01-03-2006, 07:50 PM   #171
In my post above I mentioned I burned up the fan. I took my muchmore unit to radio shack and they suggested this as a replacement fan. The fan and heatsink looked very similar to the one on the much more unit and the holes looked very close to matching up. And the voltage range was 10-13v so it seems like it would work. Do you agree ?
Also the fan has 3 wires, a black, red and yellow
which 2 would i need to use on the much more unit ?
here is a link to the fan I am talking about,
http://www.radioshack.com/product/in...tId=2102820&cp
Old 01-03-2006, 08:06 PM   #172
Remove the yellow. Thats for CPU/MB with temp controlled sensors and you will be fine.
Tony Vega is offline   Reply With Quote
Old 01-03-2006, 08:26 PM   #173
tony vega -- do you think this fan will have enough output to keep the unit cool ?
Old 01-04-2006, 11:56 AM   #174
TeamPink91's Avatar
Send a message via AIM to TeamPink91
I had to use that exact same fan on my cooler because I broke some blades on the stock fan, and the radio shack fan is nowhere near as powerful as the one that comes on the cooler from the factory.
TeamPink91 is offline   Reply With Quote
Old 01-04-2006, 12:07 PM   #175
So will it work or is it best to try and contact muchmore for a new fan?
I hightly doubt they will sell just the fan.
anyone know a good replacement or what the specs are on the muchmore fan?
I am sure I could find something on the net from an electronics supplier if i had the specs
Old 01-04-2006, 01:51 PM   #176
TheCoolCanFanMan's Avatar
Hi Cool-Can-Fan-Man here try these links they may help, good luck
http://www.bisonic.com.tw/?PHPSESSID...5d0126048ec40a
http://www.made-in-china.com/product...an_(9025).html
http://www.pccasegear.com/category9_1.htm
http://www.sonicedge.com.tw/slider/menu.htm
http://www.delta.com.tw/
I think that's enough don't you
Cheers TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 01-04-2006, 01:55 PM   #177
Originally Posted by Trakside Trucke
Appreciated all the links but I still have no clue which one to get. I need some specs so I can match the power of the much more unit fan's output. The one guy said above that the radio shack unit which looks like a direct replacement for the much more unit does not have the same cooling power as the much more fan.
Old 01-04-2006, 01:59 PM   #178
I was hoping somebody could give me a direct link to a fan that would work, lol
cause i am clueless
Old 01-04-2006, 02:07 PM   #179
also my next question is I didnt catch that the fan was stuck right away and the heat sink got very hot, I unplugged it all and let it set. Can you harm the Peltier unit by getting too hot ?
Old 01-04-2006, 02:13 PM   #180
XrayFK's Avatar
A peltier unit will be damaged by heat.
XrayFK is offline   Reply With Quote
FS MuchMore Motor Cooler sig sour R/C Items: For Sale/Trade 1 03-17-2008 04:57 PM
Muchmore Motor Cooler DoH Australia For Sale/Trade 2 12-29-2007 01:13 AM
FS: MuchMore Motor Cooler xxx787 R/C Items: For Sale/Trade 5 12-03-2006 01:06 PM
MUCHMORE motor cooler scottw R/C Items: For Sale/Trade 4 04-06-2006 07:25 AM
WTB MuchMore Motor Cooler erock1331 R/C Items: Wanted to Buy 0 12-13-2005 05:59 PM
