Old 05-16-2005, 01:08 PM   #1
nw racer's Avatar
Default rubber tire resurfacing?
Is there a way to remove the top layer of rubber without ruining the tires? I have a bunch of Take Off CS 27's that I would love to get more use out of but traction is running slim on them.
Any help would be appreciated of anything I can do that wouldn't ruin the tires.
nw racer is offline   Reply With Quote
Old 05-16-2005, 02:25 PM   #2
newracer's Avatar
R/C Tech Charter Subscriber
Do you clean them? I clean my tires with simple green between rounds and makes them like new.
newracer is offline   Reply With Quote
Old 05-16-2005, 02:26 PM   #3
nw racer's Avatar
Normally I use motor spray which seems to get them very clean, but I have stopped using that cause I noticed it causes them to crack.
Old 05-16-2005, 02:35 PM   #4
axel's Avatar
wd-40 will soften the tires if kept in a plasic bag. The longer you keep it in the softer it will become, this is good for cleaning them up, thn after apply the tracion sauce.
axel is offline   Reply With Quote
Old 05-16-2005, 02:37 PM   #5
Redwings's Avatar
You could also use brake cleaner and a little elbow grease (LOL) usually does the trick.
Paul
Redwings is offline   Reply With Quote
Old 05-16-2005, 02:54 PM   #6
nw racer's Avatar
is there any way to turn them on a lathe? Get to the fresh rubber..
Old 05-16-2005, 02:55 PM   #7
axel's Avatar
a tire truer?
Old 05-16-2005, 02:56 PM   #8
nw racer's Avatar
yea, are you able to do that with the rubbers?
Old 05-16-2005, 02:59 PM   #9
axel's Avatar
http://www.teamcobra.com/cobra/tirelathes.htm
i'm pretty sure.
Old 05-16-2005, 03:03 PM   #10
TEM
TEM's Avatar
If you look at the specs on the integy/eagle lathes, some say they will resurface rubber tires with the special bit? I enquired about that. And it's absolute BULL SH*T. Think about it; the tire has a round cross section but the cross feed on the lathe is straight. What will you achieve? Besides, when the top surface on rubbers is used, it's used! What is turning it good for? All I remember is for certain spec classes that limits the use of crappy tires, scuffing them with coarse sand paper on a lathe makes them grip better. In any case, the best you can do is clean the tires with cleaner as suggested above. If you run on carpet and neglect to clean your tires you will find a tough crud on the edges that need scraping to remove.
TEM is offline   Reply With Quote
Old 05-16-2005, 03:08 PM   #11
nw racer's Avatar
even with cleaning the tires I get the crud on the edges on a few of the tires and I think that is what is causing the loss of traction. Maybe I will try a very fine sandpaper and see if that will help a bit. I do clean my tires after every run and that does seem to help some.
Old 05-16-2005, 03:09 PM   #12
howard hudson's Avatar
thats because motor spray dries out the oils in the rubber. the simple green trick is the best.
just how many runs do you expect on these tires ???
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 05-16-2005, 03:11 PM   #13
nw racer's Avatar
I had a feeling that was what was going on. That's why I stopped using motor spray.
If I can get 7 or 8 runs out of them I will be happy. If not, then I buy more!!!
Old 05-16-2005, 03:22 PM   #14
well if you start using sandpapper . cut that in half
Old 05-16-2005, 04:32 PM   #15
teammediocre's Avatar
yokomo makes a rubber tire sander it's on there website somewhere.
teammediocre is offline   Reply With Quote
Rubber tire help nomaak Electric On-Road 5 06-25-2007 07:18 PM
Rubber Tire Lot, new and used dmayhew25 R/C Items: For Sale/Trade 11 11-04-2005 12:40 PM
TOP 1/10 Rubber Tire topgluer Electric On-Road 9 10-15-2005 04:07 PM
Rubber Tire vs. Foam Tire on Carpet dizzy1 Electric On-Road 34 06-07-2005 02:51 PM
Track Resurfacing dontfeelcold Electric On-Road 3 04-07-2004 12:15 PM
