Old 04-24-2013, 01:16 PM   #1
Default HPI Sprint 2 flux-beginner with a few questions
Hello, I was hoping just to ask a few questions. I've just received a HPI sprint 2 flux from ebay as my first R/C car for a while and my first electric!
I just was wondering if when rolling the car it should feel a bit "lumpy" it does seem to roll smoothly, and the pinion gear when not meshed with the spur seems to rotate with the magnets making it a bit "lumpy". Is this normal?
I am also wondering how to check that its in LiPo mode, as I cant work out how to get into the ESC menu as the manual shows there being a button, which I can seem to find?
And finally would the HPI Flux Reload Pro would be able to help me in the ESC menu? or would that not work for that kind of thing?
Thanks for taking the time to look!
Adrian
03area is offline   Reply With Quote
Old 04-24-2013, 02:40 PM   #2
Marv's Avatar
Adrian
New?
Used?
You have a manual -
Is the ESC in your car the same as the manual?
Marv is offline   Reply With Quote
Old 04-24-2013, 02:45 PM   #3
Sorry, It was brought used, however it has only been used once from the previous owner. The ESC show in the manual is the one with an external button, which is the same as the instruction for the car which I downloaded from HPI. However the ESC on the car has no button/switch. It simply turns on once the battery is connected.
Old 04-24-2013, 02:50 PM   #4
Marv's Avatar
Has to be an on/off switch somewhere unless the owner cut it out of the system...
What's the eBay auction number so I can see the pics that were posted -
That might help -
Old 04-24-2013, 02:53 PM   #5
ebay.co.uk/itm/HPI-Sprint-2-Flux-2-4GHz-Porsche-911-GT3-106165-Combo-/251255758521?_trksid=p2047675.l2557&ssPageName=STR K%3AMEDWX%3AIT&nma=true&si=2f%252FqP09vEtZMKZanB3Q qqDhqZ58%253D&orig_cvip=true&rt=nc
That is the listing for the car, however there isn't any pictures of a top down view. If you know of how i can post a picture to this thread then I can do that now and show you.
Old 04-24-2013, 02:57 PM   #6
Marv's Avatar
Got it...
Yeah, you need at least 10 posts to do links and pictures...
Does your ESC look like this one - http://www.rcplanet.com/HPI_Racing_S.../hpi105906.htm
Old 04-24-2013, 03:00 PM   #7
Marv's Avatar
What battery did it come with?
Page 38 & 39 in the FLUX manual tells how to program/set the ESC.
You can email me pics and I can try to sort it out if you want =
Let me know & I'll PM you my email addy -
Old 04-24-2013, 03:02 PM   #8
NO, the ESC is all black with a orange "vapor" label on the outside edge. The cooling fins are black and are about 3/4 inch high. also has the 3 bullet connectors on the right hand side. if you search HPI sprint 2 ESC on google images, there is one on there.
Old 04-24-2013, 03:08 PM   #9
Marv's Avatar
Which manual did you download? What's the manual number - ?
Old 04-24-2013, 03:08 PM   #10
I'd much appreciate it if I could have your email to try and get any concerns sorted!
Old 04-24-2013, 03:09 PM   #11
It was the manual that came up on HPI's website under manuals for the sprint 2 flux.
Old 04-24-2013, 03:13 PM   #12
Marv's Avatar
The UK site or USA site?
I have a copy of the add on update showing the VAPOR ESC -
Hang on a sec ---
Old 04-24-2013, 03:18 PM   #13
Marv's Avatar
http://www.hpieurope.com/manuals/pdf/100424.pdf
Does this look like the ESC?
Old 04-24-2013, 03:18 PM   #14
Well It was the UK site for the manual download. and both showed the programming via a button nex to the ESC block. If you PM your email, I'll send you pics of what the manual shows and what is on the car.
cheers
Old 04-24-2013, 03:22 PM   #15
Marv's Avatar
Done - Check your PMs
