Old 04-22-2013, 06:03 PM   #1
Trader Rating: 24 (100%+)
Default Best 1/8 Non-Ballooning Tire?
Another "best" thread.
I'm looking for a slick or a high traction 1/8th tire that does not balloon. I'm using the X0-1 tires and they do not balloon but the compound is a little too hard. If they were only just a bit softer they would be perfect.
If anyone has some links of what you've used that worked please post them up.
.......__________________
....../_==o;;;;;;;;__ _____]
.....), ---.(_(__)
....//___// Support NRA!
got_nitro is offline   Reply With Quote
Old 04-22-2013, 06:31 PM   #2
Suspended
The only tires that do not balloon are foams.
RogerDaShrubber is offline   Reply With Quote
Old 04-22-2013, 06:42 PM   #3
phildoggg's Avatar
http://www.brucknerhobbies.com/cgi-local/cart.pl
look for the grp revo b tires i have a set and they don't balloon. they are shorter than the xo-1 tires though.
phildoggg is offline   Reply With Quote
Old 04-22-2013, 11:53 PM   #4
M3Man03's Avatar
Incorrect. Poster is looking for a belted tire.
I use these:
http://www.sweepracingusa.com/18-GT8_c_25.html
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 04-23-2013, 12:37 AM   #5
Suspended
I use these:
All rubber tires balloon, even those 1/8th belted ones you linked, watch them in slow motion and measure the deformation cause by inertia. They might not grow to 4 times their size like an offroad tire will, but, even 1mm is still the tire ballooning. The only tires that do not deform from inertia are foams and any other solid material that cannot stretch.
Old 04-23-2013, 06:54 AM   #6
M3Man03's Avatar
Foam tires do the same thing, sorry say.
Foam inherently is a elastic material.
I have a set of foams and a set of those Sweep belted tires - they both slightly expand about the same amount under load.
Old 04-24-2013, 04:20 AM   #7
Thanks all, I'll take a look at the links. I like foams just hate the chattering in a turn.
.....), ---.(_(__)
