Old 03-27-2014, 08:11 AM   #16
I got the infinite 7500 mah 90C packs. Can these batteries be charge higher than a 1C charge rating? I been charging max amp lipos at 2 to 3 C...no issues. What is the max C ratings of infinite lipos packs?
thanks
crittertoo is offline   Reply With Quote
Old 03-27-2014, 08:23 AM   #17
Trader Rating: 132 (100%+)
I have the 6200 pack probably has about 100 cycles on it. After about 20 cycles the IR dropped to 1.4 per cell! Impressive, yes. Anyways best battery Ive ever ran, no puffing and plenty of power. I keep mine about 60-70% charged when not using them, no sign of puffing, I charge them at 10 amps. The battery starts out at 1.9 IR and drops to 1.4-1.5 by the 3-4 time running (about the 3rd heat or main). Also super light at 294 grams.
thecaptain is offline   Reply With Quote
Old 03-27-2014, 08:29 AM   #18
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
I have had the same packs for a yr now and only slightly higher IR than new (so my thunderpower charger says) and 0 puff with over 300 cycles to 70%....
the new 7500 packs r 20g heavier tho ... be warned
wish I could still get the 7200s fresh
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 03-27-2014, 08:50 PM   #19
Odin544's Avatar
Trader Rating: 93 (100%+)
7200?? I've only seen the 7500 90c and 7000 80c
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
