Help with motor identification?
Help with motor identification! I have a purple ring Novak brushless motor with the sensor wire internally fixed in the end bell. The white serial number sticker is R018832. Does anyone know what turn motor this is? Or how can you determine what turn a brushless motor is after the number sticker has worn off?
Originally Posted by Braincell2
(Post 12053847)
http://www.teamnovak.com/products/br...spec_chart.htm Look up on the table SS Pro motors. I assuming the purple band you are speaking of is in the center of the motor. Novak uses a color code system based on the color at the timing ring (Sensor side of the motor). The table lists all the color codes. Shawn |
Originally Posted by Shawn68z
(Post 12054631)
