Old 04-15-2013, 03:33 PM   #1
Tristian93's Avatar
Exclamation need help with hobbywing xzrun 8.5t motor
i can't get it connect to my transmitter is there a transmitter you need because i have one for my hpi maverick i have been thinking about a flysky transmitter. the hpi one it will not pick up neutral point on the transmitter can anyone help please
Tristian93 is offline   Reply With Quote
Old 04-15-2013, 06:47 PM   #2
lewis110's Avatar
Are you calibrating the speedo? Press the red set button and turn the esc on. Hold for a few seconds after its turned on and then it should blink. Leave in neutral hit button should flash once. Then wide open, hit button. Should flash twice. Then full brake, hit button. Should flash 3 times. Then after Appx 5 seconds should be good to go.
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 04-16-2013, 12:20 AM   #3
Tristian93's Avatar
Exclamation
Yeah I have done that all urmm I just won't connect if you go on YouTube and look up hobby xzrun 8.5t help setting up it by me the name is zackgash
Old 04-16-2013, 03:45 AM   #4
lewis110's Avatar
Just wondering, where did you buy it? Was it off ebay or from a dealer. I first I would see if you can get a different receiver to try. If that doesn't work contact the place you bought it. There is something wrong with it.
One thing I noticed on the video you kept your finger on the set button to get neutral. It looked like the first time you took it off and it wouldn't connect. I just wanna be clear with what I seen. Once it starts blinking you need to take finger off and repress the button.
Old 04-16-2013, 05:46 AM   #5
Tristian93's Avatar
I got it from a shop from in Japan I can't remember
What it's called but it's got the Holograms on the box
It's all real but I think it could be the Transmitter
It's off a hpi maverick and it dose not have
No Option on it
Old 04-16-2013, 06:59 AM   #6
lewis110's Avatar
See if you could barrow a transmitter/receiver from someone. If it works then, then you can get a new transmitter. I have used very cheap stock Losi/spectrum transmitters without problems.
Old 04-16-2013, 12:52 PM   #7
Tristian93's Avatar
I have I got a flysky on Order just waiting for it to get here
Old 04-17-2013, 07:22 AM   #8
Tristian93's Avatar
IT ON MY HOBBYWING IS WORKING YEAHHHHHH BOOOYYYYYYYYY !!!!
