Old 05-13-2005, 01:10 PM   #1
Buck Nasty's Avatar
3 oz wight loss.
will this help much racing sportsmen stock?
Buck Nasty is offline   Reply With Quote
Old 05-13-2005, 01:13 PM   #2
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Well think about it this way and then re-think your question....3 oz is 5.7% of the 52oz legal weight...so if you can gain that type of weight advantage then it would be huge...tell an F1 or NASCAR team that they could be 3% lighter then the competition and you would have a dominate car....Oh WAIT BAR already tried that
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 05-13-2005, 01:17 PM   #3
Sure shedding 3 oz will get you to that first contact with the wall quicker!!
I just run club races, and for the most part its not the fastest guy that wins, its the guy who can keep it between the boards most consistently.
MartynD is offline   Reply With Quote
Old 05-13-2005, 01:19 PM   #4
Buck Nasty's Avatar
will when you put it like that things are sounding better all the time. Maybe I can start putting this car closer to the front of the A instead of the middle.
Old 05-13-2005, 01:22 PM   #5
Buck Nasty's Avatar
the boards have not been a problem for me racing on-road.
Old 05-13-2005, 02:27 PM   #6
ChadCapece's Avatar
I used to get my EP touring cars as close to 1500grams as possible. Then when I got my Yok, it weighed 1600 grams (+4oz.) I thought this was going to be a huge disadvantge, but on asphalt, I actually could get more traction and stability with the added weight. There's a section the the backstraight where the 415's, FK05's, and JRX-S's always hit and jump alittle then bottom out. I won't get out of shape like those cars, and I think the extra weight helps.
If your track is smooth and/or tight, go for a light car. If you have a sweeping or rough(bumpy) track, then the extra weight may be an advantage.
ChadCapece is offline   Reply With Quote
Old 05-13-2005, 04:02 PM   #7
edseb's Avatar
It all depends where it is located. If you take it out of the drivetrain, or extreme ends of the car, you'll feel it more since there is less weight affecting the acceleration or weight transfer/ roll center/ cg.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-13-2005, 04:11 PM   #8
Buck Nasty's Avatar
he weight as removed from all over the chassis (XXX-SG+) so it is pretty balanced. There is 1oz added to the motor/speedo side to balance out the weight. I will run it for the first time this weekend so we shall see............
Old 05-13-2005, 07:10 PM   #9
Send a message via AIM to greencactus3
that may be so but also lighter mass equals less momentum so less damage.
greencactus3 is offline   Reply With Quote
Old 05-13-2005, 08:51 PM   #10
Jack2's Avatar
Yes, Very true.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 05-13-2005, 10:05 PM   #11
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
I used ta be ragged upon cuz My Xray weighed in at about 1620g But I was still winning My class. Now I'm running as close to 1500g as possible and I gots ta rework my suspension. I also moved the battery but in turn was able to remove all that added lead (for balance) now the car should run more like it was designed to.
PlainOleDave is offline   Reply With Quote
Old 05-13-2005, 11:09 PM   #12
an XRay weighin in at over 1600g
Mine weighs around 1440g for club races... and its built per instructions with the only hop up being the spring steel axles on the front. (oops not weighed it since I added the battery brace)
Old 05-14-2005, 12:08 AM   #13
I had laid it out with stick-pack down one side (like the FK05) and had to add that much to balance it. But it worked!
Old 05-14-2005, 06:22 AM   #14
TigeRyan's Avatar
Geeze...for the Region 2 Carpet race I had to add almost every weight in my box to get my car up to weight....and I was running a motor fan, which electronics are you using????
Old 05-14-2005, 10:14 AM   #15
FP9451 digital servo, Novak XXtra rec. and a Novak tempest ESC. But again, I was running an EVO2 with the six cell stick pack down one side. I know it wasn't designed to do this but I made it work for me. (by adding weight)
Range Loss rgrg2 Radio and Electronics 2 08-18-2008 10:35 PM
WTB Wight Nylon Associated Front End Parts kang45 R/C Items: Wanted to Buy 0 02-29-2008 09:29 AM
MY LOSS IS YOUR GAIN ghöst R/C Items: For Sale/Trade 14 08-29-2005 06:47 PM
Loss of a legend. RIP Big Jim Cain Electric On-Road 8 06-17-2005 11:24 AM
zero loss connectors was ist los? Electric On-Road 11 02-19-2002 08:35 AM
