Old 04-12-2013, 09:55 PM   #1
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Default 40 mm fan
I have noticed that many people are running 40mm fans to help control motor temps, but I was wondering specifics on these fans. The only one I've found info on is one from zeppin racing:
Voltage: 5-7.5V
Start-up Voltage: Approx. 3.5V
Rated Current: 0.37A10%
Consuming Power: 1.85W15%
Air Flow: 9.1 CFM
Spinning Speed: 9000RPM15%
Noise: 37.20dBA
Connector: FUT
Cable Length: 240mm
Fan Size: 40x40x10mm
Can computer fans work if I find one that is 5v-7v?
Do I need to be concerned with amps?
Is 9.1cfm too much?
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 04-13-2013, 01:34 AM   #2
wtcc's Avatar
I only use 40mm PC fans. 6V and two wires. Forget the noise, it doesn't matter in our sport. And the best thing is the price
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 04-13-2013, 01:52 AM   #3
the zeppin racing crazy fan is really good, used yeah racing tornado 30mm before, but the crazy fan 40mm makes quite a big difference, good price too!
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 04-13-2013, 04:34 AM   #4
hanulec's Avatar
Trader Rating: 27 (100%+)
40mm fans aren't ROAR legal. Its not about the fan size.. Its about how the air is moved by the fan.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-13-2013, 05:48 AM   #5
What can I use that is roar legal that can drop temps around 10 degrees?
Old 04-13-2013, 06:07 AM   #6
hanulec's Avatar
There are many options...
I'm biased -- I have my Side Piece Racing Seis fans that I always run...
Old 04-13-2013, 01:10 PM   #7
izzyracer's Avatar
Where can we get one?
Izzy
izzyracer is offline   Reply With Quote
Old 04-13-2013, 01:26 PM   #8
Trader Rating: 60 (100%+)
I recently switched from a LRP 40mm fan to the Seis 25mm fan and the motor was only 5-10 degrees F higher.
The seis should easily drop your motor 10 degrees, probably much more than that!
http://shop.awesomatixusa.com/parts.html
PROMODVETTE is offline   Reply With Quote
Old 04-13-2013, 02:21 PM   #9
Has anyone used a 5v 40mm fan?
