Old 05-12-2005, 01:52 PM   #1
edseb's Avatar
Default Peak Hellfire vs. Monster pro stock motors
I just got a Peak Hellfire stock motor from a friend and want to test it in Onroad. I've always run Monster stock pros, and really liked their performance. Can someone tell me about this motor. How it should be geared, it's characteristics, what I should expect?
I usually gear my Monsters at 7.0 or close final gear ratio with rubber on asphalt tracks.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-12-2005, 02:27 PM   #2
TRF415boy's Avatar
It's very well named that motor. It heats up like the fires of hell, and don't go quick. I tried to have mine go, but i found it much easier to put a monster and be (relatively as it's still a stock) quick again.
Still, if you want to try it, it needs gearing like hell(fire), we normally use about 8.2 on the monsters at the track i used to do stock, and i was gearing the peak at 6.5. If you try gearing it lower, it'll still heat like a mad, but won't be quick at all.
TRF415boy is offline   Reply With Quote
Old 05-12-2005, 02:57 PM   #3
edseb's Avatar
So should I even bother? Sounds like no one uses this motor for a good reason.
Carl Hyndman
Old 05-12-2005, 03:08 PM   #4
rod_b's Avatar
Send a message via AIM to rod_b
red/green springs. narrowed brushes. geared between P2K and P2K2.. I run mine in the low 6s. For reference, I run monsters around 7s like you.
rod_b is offline   Reply With Quote
Old 05-12-2005, 03:19 PM   #5
edseb's Avatar
Thanks. Yeah, the stock springs are red/green, and as far as brushes, do you run 767s and cut em down? If so, trailing end? In monster stock I like to shave a little off the trailing edge.
Carl Hyndman
Old 05-12-2005, 09:42 PM   #6
edseb's Avatar
It sounds like it is a torque motor.
Carl Hyndman
Old 05-12-2005, 10:33 PM   #7
Yeti35's Avatar
So you are lookin for some more speed ehh!!! This mean you are a little worried about us down here in the valley?!!
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 05-12-2005, 11:26 PM   #8
TRF415boy's Avatar
Did that, and tbh it wasn't nearly as good as just an out the box monster.
Old 05-13-2005, 04:35 AM   #9
Yokibear's Avatar
I race in a club class in Australia and the Peak Hellfire is the only motor we are allowed to use!Yeh they get hot but there pretty bullet proof.I gear my Yokomo's to 5.88.
CORALLY RDX
AERCCC Member #18
Yokibear is offline   Reply With Quote
Old 05-13-2005, 07:37 AM   #10
Peak Hellfire is like an MVP (almost identical...)
Gear it tall, may want to try around 6.0, and you can also try narrowed 766 brushes, which will help with the temperature.
CHeck www.rccars.com, Big Jim's motor forum and do a search for "MVP and "Tuning" you should find a few suggestions.
MartynD is offline   Reply With Quote
Old 05-13-2005, 10:42 AM   #11
whoopass's Avatar
I had a Hellfire, used it once and now it is powering my lathe!
whoopass is offline   Reply With Quote
Old 05-13-2005, 06:14 PM   #12
edseb's Avatar
Sounds like this motor is just a paper weight. Oh well, it was something I got, so no harm.
Yeti:
I'm always looking for more speed.
Carl Hyndman
Old 05-13-2005, 06:15 PM   #13
edseb's Avatar
BTW, I had a MVP too, and that thing is a paper weight now.
Carl Hyndman
Old 05-13-2005, 11:11 PM   #14
Mine is going the same way
Old 05-14-2005, 03:56 PM   #15
Trader Rating: 36 (100%+)
I use mine for a brush cutter.
EVILGRAFX is offline   Reply With Quote
Trinity Co27 Monster Stock Pro Motors & Reedy Neo 2* BL Motors For Sale Leodis R/C Items: For Sale/Trade 17 05-11-2007 06:03 PM
Stock Motors - Monster and Binary Stock Nexus R/C Items: For Sale/Trade 3 04-25-2004 03:47 PM
8 brand new trinity stock motors paradox blue endbell#2104 & new monster stock #2140 jason cheng R/C Items: For Sale/Trade 11 05-08-2003 06:33 PM
New Peak Hellfire Stock Motors For Sale olewarrior R/C Items: For Sale/Trade 1 01-26-2003 10:33 PM
WTB--Orion or Peak stock motors scott R/C Items: Wanted to Buy 2 11-01-2002 02:54 PM
