Old 05-12-2005, 06:24 AM   #1
Default lathe ? ball bearings or v guides ?????
how do you know which one to is better for you
rcfreak24 is offline   Reply With Quote
Old 05-12-2005, 06:28 AM   #2
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
V-guides provide a better supporting surface for a better cut. Bearings can go bad, so i would suggest getting V-guides.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 05-12-2005, 06:30 AM   #3
don't the v guides wear grooves in them though . the lathe i'm looking to purchase is a hudy executive comm lathe . is automatic good or manual do it yourself better
Old 05-12-2005, 06:33 AM   #4
Trips's Avatar
Trader Rating: 16 (100%+)
I'd have to vote for the V-guides, In ten years I haven't seen any sign of wear on my Cobra lathes guides. Keep em lubed and don't run the O-ring too tight and they'll outlive you.
The Hudy Executive is one fine lathe... if I were buying a lathe now, that would be the one I'd buy.
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-12-2005, 06:36 AM   #5
i figure i should get a pretty good one and i don't want to have to turn around and get a new one next year . i want something that's going to last a hudy builds quality products
Old 05-12-2005, 07:27 AM   #6
That is right. So buy the hudy and get the V-blocks. I personally run carbide bits from McMaster Carr, but some perfer the diamond bits....they're pricy though @ $100.00 and you'll cry if you chip one by accident. You don't need the automatic version of the lathe.
Old 05-12-2005, 07:28 AM   #7
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I have that lathe and as long as you have someone who knows (and I mean not the kid who says he knows but a expert driver or really old guy who still races and has been for 10years) how to set it up...It does require you to make sure it perfectly square and measured for perfect fit. Make sure they show you how to use it properly and have them watch over you your first few times.Make sure there are no rattles or that it is making any bad noices...USE BUSHING OIL ON YOUR V GUILDS.....makes it much easier.
Also run yours off a charger that allows you to set the voltage if you have one.
Lots of guys use a four cell pack....that much voltage is not needed. I set my charge to put out 2Volts and thats it...Makes for perfectly polished comms.
Hope this helps.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 05-12-2005, 07:49 AM   #8
Regional Moderator
Mark Mixon's Avatar
Default Lathes
V-blocks are the only way to go. Bearings each have 1000ths of play,some more, multiplied by four, it adds up. Cobra lathes have a round area for the shaft which wears out and results in play. Stick with the HUDY or a comparable model, the extra money is worth the precision and durability.
FSEARA
"They may be toy cars, but I spend REAL money to race them!"- Racer X
"It's only a big deal if you make it one."
Mark Mixon is offline   Reply With Quote
Old 05-12-2005, 08:01 AM   #9
Oh yea there is a debate on which is better but IMHO Diamond bits are the best and last forever.
I have had no problems with my HUDY either...My old Cobra did give me soem trouble toward the end.
Stephen <><
Old 05-12-2005, 08:35 AM   #10
Trader Rating: 35 (100%+)
I bought the Integy/Xipp (after selling my Hudy), and I find that the Integy/Xipp works as well as the Hudy, however, I made the mistake of opting for bearings on the Integy. The bearings now bind (probably filled with copper shavings) and the process requires more babying.
I'd recommend "V" guides. I won't promote one brand over another though.
Geppetto is offline   Reply With Quote
Old 05-12-2005, 10:29 AM   #11
Matt Howard's Avatar
definitely V-guides. My twister is 15+ years old and it still cuts perfectly with the same diamond bit in it the whole time
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-12-2005, 11:40 AM   #12
Qwiglee's Avatar
Coke or Pepsi?
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 05-12-2005, 11:47 AM   #13
jw92656's Avatar
Smile
I agree with V guides. As long as you use oil on the guides, they will provide a better cut and last for ever. Go with McMaster Carr carbide bits, and a Diamond file. Ordered them on Monday morning, and got them Tuesday afternoon. Insane turn around..... One bit, and a file cost me $29.99 total.
jw92656 is offline   Reply With Quote
Old 05-12-2005, 12:04 PM   #14
jw92656's Avatar
Smile
Old 05-12-2005, 12:05 PM   #15
asw7576's Avatar
I have Hudy with V guide. V guide is okay, simple design with great results. One thing I don't like about Hudy lathe is the vertical plates that hold both end of the rotor. ( one plate is where the motor slave sit, and another plate for holding commutator ). I'm sure those plates are not 90 degree perfect to the side nor the bottom. I have to make correction and adjustment to ensure the rotor shaft are perfectly align to V guide If Hudy is a premium brand for precision and quality........ well, I don't see the precision for that particular lathe.
Lrp V8.1 , Peak 14X2 , Hudy Lathe V guides Jason Pelletier R/C Items: For Sale/Trade 9 12-18-2007 10:23 PM
FOR SALE NIB HUDY TECH LATHE W/ V GUIDES nolan_racing R/C Items: For Sale/Trade 24 10-29-2007 06:00 PM
Hudy ADVANCED LATHE with steel V-guides CGR R/C Items: For Sale/Trade 0 07-20-2006 10:38 PM
TECH COMM LATHE with steel V-guides jc510 R/C Items: For Sale/Trade 10 09-21-2004 01:33 PM
V-Blocks or Ball Bearing guides? Cardboard Electric On-Road 7 06-04-2004 05:56 AM
