Like Tree3Likes
TRF101
Old 09-14-2013, 07:28 PM
  #796
Trader Rating: 19 (100%+)
Has anyone ran the exotek front end on this yet? I'm thinking of tryin it because it's easier to adjust camber/ caster, just curious if anyone else has any experience with it on this car.
Chris Brown is offline
Old 09-14-2013, 08:05 PM
  #797
hanzo3's Avatar
Trader Rating: 55 (100%+)
Just my luck they discontinue when I buy one. What are the weak points of this car? You think the upper A arm can break even if its carbon
Fiber?
hanzo3 is offline
Old 09-14-2013, 08:17 PM
  #798
edhchoe's Avatar
Trader Rating: 41 (100%+)
IMO, The rear carbon shaft is the weakest part. If you crash into a wall sideways it will weaken the shaft and make it bend/split.
edhchoe is offline
Old 09-14-2013, 08:33 PM
  #799
mtveten's Avatar
Trader Rating: 29 (100%+)
Originally Posted by badboy
Hi.
Will these fit in the TRF 101?
Tamiya (#54158) F104 Diff. Housing Set
Tamiya (#54162) F104 Carbon Rear
If yes, is it a direct fit or you have to modify something? Also, in terms of width, will there be a difference also?
Thanks.
Yes it fits but you will also need the left side hub as well since the 104 hubs have a different offset. Using the 104 axle assembly on a 101 will widen the car 6mm.
mtveten is offline
Old 09-14-2013, 08:34 PM
  #800
mtveten's Avatar
I am currently running this setup and prefer the available with it.
mtveten is offline
Old 09-14-2013, 08:49 PM
  #801
badboy's Avatar
Trader Rating: 14 (100%+)
Thanks.
May in know what's the part number of the left hub?
badboy is offline
Old 09-14-2013, 08:56 PM
  #802
hanzo3's Avatar
Is the carbon shaft the same as tr f104?
hanzo3 is offline
Old 09-14-2013, 09:08 PM
  #803
aussierevo's Avatar
Fiber?
I've found the weak point is the front arms, but not from carbon breaking but from balls popping out top and bottom. I've tried to solve and even yesterday when running had them pop out and I didn't hit anything. I've switched the arms over to the exotek as I never once experienced this problem in 4 yrs of running my f104 pro
aussierevo is offline
Old 09-14-2013, 10:38 PM
  #804
-jacob-'s Avatar
Has anyone actually broken a carbon shaft. I crashed hard at fasttrax, broke the side links, center plastic piece, that's about it...
-jacob- is offline
Old 09-14-2013, 11:06 PM
  #805
edhchoe's Avatar
Well. You can make it fit with f104 diff housing and f104 wheel adaptor. See the posts above.
Yes, mine broke. It wasn't pretty. It took the rear 1060 bearings with it.
edhchoe is offline
Old 09-15-2013, 11:08 AM
  #806
Trader Rating: 39 (100%+)
I broke mine as well. Definitely hit the wall hard. So I don't think it's neccesarily a weak part, but without available replacements I think Tamiya has set people up for failure with a somewhat expensive purchase price. I have found the front to be very strong.
Snick2011 is offline
Old 09-15-2013, 03:08 PM
  #807
Cridd's Avatar
Trader Rating: 16 (100%+)
I have a brand new TRF in the box, still plastic wrapped if anybody wants to buy it for 425 shipped to lower 48.
Cridd is offline
Old 09-16-2013, 04:03 PM
  #808
shadowracer24's Avatar
Ran its first real race yesterday in the florida state series race and the car was hooked. Set tq and was told that it also set a new track record at the track we were at. As soon as I get the setup sheet finalized I will get it on here for you guys.
shadowracer24 is offline
Old 09-18-2013, 02:14 PM
  #809
RCformula1's Avatar
Good news from Tamiya on another production run of the TRF 101:
http://rcformula1.com.au/index.php/h...production-run
RCformula1 is offline
Old 09-18-2013, 06:19 PM
  #810
subaru73's Avatar
Trader Rating: 42 (100%+)
Default Trf 101
That is great news !
subaru73 is offline
