TRF101
#286
#287
To be honest I would go back to the 575 rears. It may be all tires, did you ever try the 574 front?
One other thing that might help would be going back to the silver side spring but preload it at least 1 full turn. That will help stabilize the car, but it will still roll and maybe help your mid corner.
I think with the low track and air temps the 575 we're the way to go. I did sauce up and heat the 572, but they are very old tires. I've not tried the 574 as the 571 work well, but you've made me think this over a bit more. Worth a try.
I will give the silver spring a try as suggested. I was wondering if moving the link from the middle hole as per manual to the inner hole would help as well to give it more roll. Will be something else to try this weekend.
#288
#289
Kingpin is good. But I think this is the lowest I can get the front. Just got esc installed. Time for test and tune
#290
Thats why places like rcmart and tqrcracing will always get my dough same day shipping and tracking number.....and i know of the time change in Hong Kong!
#291
Ready for the track!
#293
5mm front and rear
#296
edhchoe: What all did you have to do to get to 4.4mm?
#298
Quick one guys, do you need to cut the lugs off the servo to fit it? or is it ok with the lugs on?
#299
Posted a few scanned pages from RC World of Satoshi Maezumi's TRF101. You can find them all here; http://kentech.blogs.se/
#300
It shows how different Satoshi Maezumi's TRF101 is to what we normally use. Formula Tuned 32T motor, LiFe battery, original F104 tyres and it's fitted with the Tamiya TGU-01 gyro.
