Old 05-10-2005, 04:42 PM   #1
tc4kid191's Avatar
Send a message via AIM to tc4kid191
Default roll out
What is the equation to find your roll out?
tc4kid191 is offline   Reply With Quote
Old 05-10-2005, 04:58 PM   #2
RobS's Avatar
For a 12th scale..
Tire Size x 3.14159 / spur gear x pinion
For a touring car for a TC3/TC4
Tire size x 3.14159 / spur gear x pinion x 2.5
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 05-10-2005, 05:16 PM   #3
TEM
TEM's Avatar
The touring car formula is wrong! That only works for a TC3/4 which has an internal ratio of 2.5 Other cars don't have that ratio, change numbers accordingly.
TEM is offline   Reply With Quote
Old 05-10-2005, 08:03 PM   #4
RobS's Avatar
Oops, my bad should have mentioned that.
Rob Say
Old 05-10-2005, 10:05 PM   #5
A_Stratus's Avatar
Ya but he's running a TC4 so it's all good
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 05-11-2005, 06:53 AM   #6
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I'll go you one better Every can calculate roll-out (assuming they know the equation), but ever seen the equation for finding a pinion when someone gives you a roll-out number?? I have...here it is...
To Calculate Roll-Out:
Tire Diameter (in mm) * Pi (3.14159) / (spur/pinion*drive ratio of car)
To Find Pinion Needed:
Roll-Out * Spur * Drive Ratio / Tire Diameter (mm) * Pi
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-11-2005, 08:57 AM   #7
mo
mo's Avatar
or you can use the roll out calculator at www.gearchart.com
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 05-11-2005, 10:44 AM   #8
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
wats the * ? is that a multiplication sign or wat man? can u write how you would type it on a calculator! ty
crACkeD ChaSsiS is offline   Reply With Quote
Old 05-11-2005, 11:21 AM   #9
raving-monkey's Avatar
Send a message via MSN to raving-monkey
* = multiplication
/ = division
raving-monkey is offline   Reply With Quote
Old 05-11-2005, 11:21 AM   #10
to work out the pinion from an FDR would i just do that equation but without the 'roll-out' part?
Old 05-11-2005, 01:34 PM   #11
k_bojar's Avatar
Originally posted by raving-monkey
* = multiplication
/ = division
Thanks...
Old 05-11-2005, 01:38 PM   #12
k_bojar's Avatar
I guess...Final drive (I thought) is just:
Spur / pinion * drive ratio = FDR
I haven't done much with FDR - most guys over here worry about roll-out instead of FDR
Thinking about it...it should work....
Old 05-11-2005, 02:00 PM   #13
Default roll out.......
why is it so important? doesn't it comes down to spurgear & pinion combination I mean unless you adjust your FDR ratio by ripping off material of your tyres!
Omar R is offline   Reply With Quote
Old 05-11-2005, 02:50 PM   #14
well guys that run foams are changing their 'rollout' all the time because their tyres are wearing.
not so bad for the rubber guys because their tyres stay the same (diameter that is)
Old 05-11-2005, 03:23 PM   #15
k_bojar's Avatar
Default Re: roll out.......
Roll out is important because, like raving-monkey said, foams tires change their diameter basically every run...and that's before you true them Its not uncommon for a, say, magenta compound foam to lose about 1mm of rubber after a 5 minute run...So by doing the roll-out your car stays the same speed as it was with the larger tires...
it also helps from blowing up motors too too small diameter tires can be just as bad, on a motor, as over gearing it with a pinion and spur combo
Be lucky if you run on rubbers all year long
G4S roll bar mod - change to mugen roll bar charlesd Nitro On-Road 13 07-01-2008 01:32 AM
Roll Out - 13.5 vs 27t SWTour Electric On-Road 5 02-06-2008 03:31 PM
is my roll out right little man Australian Racing 4 12-22-2007 04:43 PM
roll out kracka Rookie Zone 2 01-21-2007 02:08 AM
Monster GT Roll Cage or Roll Bar complete or Plans? mjm R/C Items: Wanted to Buy 1 03-18-2005 05:12 PM
