Old 04-04-2013, 11:12 AM   #1
Trader Rating: 25 (100%+)
Default Breaking in TC tires for carpet
Noob questions
Is there any special type of break in I should do for rubber (sweep exp) tires running indoor carpet? And how long should the tires last before the performance falls off?
Also are tire warmers needed? I have a set of trinity's from back in the day.
gangstacoupe is offline   Reply With Quote
Old 04-04-2013, 12:20 PM   #2
Skiddins's Avatar
We've found you only really need to heat tyres if they're 32's or above.
When new we just clean with either brake cleaner or lighter fluid, then apply additive as per normal.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-04-2013, 01:21 PM   #3
orcadigital's Avatar
Trader Rating: 61 (100%+)
Run one or 2 packs through them and they are fine. I personally have the MuchMore Tire Sander (I use it for cleaning tires) and I will spin them and put some SXT cleaner on a rag and get all of the mold release and junk off of them. Works well, softens the tires and they work pretty much first time on the track for me.
Used this for various Sweep tires (mostly QTS 32) and Jaco Blues. Same technique can revive an old set of tires for me as well.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 04-04-2013, 02:43 PM   #4
SteveM's Avatar
Trader Rating: 142 (100%+)
I use Simple Green to clean my tires and let that dry completely before applying traction compound. A few minutes on the track usually scrubs them in enough and I'm set.
SteveM is offline   Reply With Quote
Old 04-04-2013, 08:08 PM   #5
Simple green works on anything!!!
After a day in the mud with my quad I spray that all over let it sit for 15-20min rinse and its just like new, even cleaned my sneakers with it lol
JOE SI is offline   Reply With Quote
Old 04-05-2013, 04:46 AM   #6
Nuno Gancho's Avatar
Simple green anyone may put a photo of it,mthanks.
Nuno Gancho is offline   Reply With Quote
Old 04-05-2013, 05:00 AM   #7
MaxThrottle's Avatar
http://buy.simplegreen.com/
Sprint 2 Flux w/ 2010 camaro body
41 willys Parma body, 68 primer gray Camaro beater body
65 Mustang coupe body, GT40 body
67 Vette kyosho body
MaxThrottle is offline   Reply With Quote
Old 04-05-2013, 07:04 AM   #8
Thanks.
how do you normally use as tire cleaner like brake cleaner or apply and let it dry then apply additive, do you use after each run.
Old 04-07-2013, 05:34 PM   #9
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
I just use the motor spray, it seems to work fine. I hear some guys use the buggy grip but I have yet to try it.
FYI if you want to keep the disk rims looking nice and white use Goo Gone with a clean rag. LIKE NEW look.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 04-07-2013, 05:47 PM   #10
SteveM's Avatar
Originally Posted by Nuno Gancho View Post
Thanks.
I buy a bag of shop rags from the local auto supply store and spray it on the rag before using it to wipe off the tires.
Old 04-08-2013, 12:51 AM   #11
nathanjohnzrc's Avatar
It depends on where you race. I use rubber tires and i did not face any problem.
Regards
Nathan
nathanjohnzrc is offline   Reply With Quote
