Old 05-10-2005, 11:40 AM   #1
acutts's Avatar
Unhappy Arghhhh SHOCKS - Help please
I am trying to build the shocks on the X-ray T1FK-05 and I can't get them built without rebound ... ! Does anyone know what the best procedure to bleed shocks is so that they are built without rebound.
In the manual it says something about turning them upside down and leaving to vent for 10mins .... well when I do this it seems to do jack .... any help greatly appreciated before the thing becomes a plane
Scott
acutts is offline   Reply With Quote
Old 05-10-2005, 11:42 AM   #2
losi jon's Avatar
it should have some rebound......
losi jon is offline   Reply With Quote
Old 05-10-2005, 11:45 AM   #3
acutts's Avatar
It says the following in the manual:
'Check shock for proper operation. The shock rod must move in and out freely with only hydraulic dampening. The shock rod should not extend out by itself when pushed in and released, nor should it be drawn into the shock body when withdrawn and released.'
Old 05-10-2005, 11:47 AM   #4
MrRolla's Avatar
Trader Rating: 29 (100%+)
This is exactly why i use TRF shocks on my Xray now..
Build easier, quicker, and stay that way longer than I could build the Xray shocks..
MrRolla is offline   Reply With Quote
Old 05-10-2005, 11:49 AM   #5
acutts's Avatar
I can't get TRF shocks as live in the UK and they real expensive ...! Anyone have any ideas on how to try and attempt the x-ray shocks ... as some guys must be using them??
Old 05-10-2005, 11:53 AM   #6
Charles Godwin's Avatar
You can get trf shocks on ebay, kinda cheap as well
Charleshttp://cgi.ebay.co.uk/ws/eBayISAPI.d...973572277&rd=1
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 05-10-2005, 11:55 AM   #7
acutts's Avatar
Thanks but don't really want TRF shocks ... want to have a try at X-ray ones first before I spend another $80 ....
There must be some way of doing it ... I used the ride air remover and then attached it all but the rebound is huge ... it when depressed goes all the way back out again on its own.
Old 05-10-2005, 12:01 PM   #8
MrRolla's Avatar
When i was running the Xray shocks, i followed the advice of a local guru, he said to use the TRF bladders instead of the Xray/serpent ones..
You could give it a try..
Old 05-10-2005, 01:30 PM   #9
I have no problems getting the 05 shocks to have little or no rebound...
I use the same method as explained on the last page of the FK'05 thread.
MartynD is offline   Reply With Quote
Old 05-10-2005, 03:33 PM   #10
acutts's Avatar
Taking the bottom cap off I seem to be having more luck getting less rebound but this also seems to be letting air bubbles back into the shock so seems a bit pointless??
Old 05-10-2005, 03:46 PM   #11
CGR
CGR's Avatar
I have lots of rebound and my car works fine. Try it out.
-Kartman
CGR is offline   Reply With Quote
Old 05-10-2005, 04:04 PM   #12
be sure to leave shock inverted the whole time.
I have no probs, if u go too far then I could see you getting air in
Old 05-10-2005, 04:24 PM   #13
Send a message via AIM to goop
when they rebound that much means that you have too much fluid in them try putting less fluid in turn them up side down open the cap by the shaft and work the shock in and out but not too far to suck in air. this is what i did and they work great a little rebound will be fine but too much is not good
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 05-10-2005, 04:28 PM   #14
If you can't get rid of all the rebound just match them up in pairs. Just try and get each one of the pair to be as close to the other as you can.
Old 05-10-2005, 06:29 PM   #15
ChadCapece's Avatar
Why is Xray the only company that suggest no rebound? Maybe you are misinterpreting the instructions. If you fill the shocks will less oil then needed, then you will have no rebound. This is known as a "dead" shock to most racers.
If all else fails, buy HPI shocks. They are the easiest shocks to build and maintain. Tamiya shocks may be more smooth (very slight deviation), but nothing compares to HPI Pro 4 shocks.
ChadCapece is offline   Reply With Quote
WTB IRC Shocks Or Losi After Shocks Or LS2 Shocks !jAsOfRaW! Australia Wanted to Buy 0 01-25-2008 02:12 AM
F/S B4 shocks MADHAT R/C Items: For Sale/Trade 0 12-29-2007 02:13 PM
JRXS SHOCKS OR TRF SHOCKS RED-LINE M03 Electric On-Road 23 10-18-2005 06:24 AM
wtb: 1/8 rear buggy shocks or t-maxx size shocks arawak420 R/C Items: Wanted to Buy 0 05-23-2005 07:05 PM
Trade: B4 Shocks for Bk2 shocks Driver1 R/C Items: For Sale/Trade 0 10-19-2004 11:02 AM
