KO Mars and SPEKTRUM
works fine with the mars radio! i love mine. i run 4 cell oval and must use a receiver pack with mine. best 140.00 i have spent in awhile! go get it!
I had some truobles with my trims being slightly off when I first got the system, but since re-centering them they've not moved.
Other than that, absolutely perfect system. Money well spent IMO.
I've ordered and can't wait to get mine. I'll be running it in my TC3 and my R40.
What are the best prices you guys have seen for the receivers?
Originally posted by Soviet
This is really great news to hear. I'm glad that I don't have to purchase a new radio for spektrum to work properly.
Come to think of it, the Mars is probably the oldest radio that will function with spektrum. I suppose it was a good buy.
Honestly, I haven't seen ANYONE I know with a KO radio have a problem with the Spektrum system in it(myself included, & I'm using it on my original Mars, had it for maybe a month & a half). I even let a friend try it on their older KO Precious & it worked fine on that one, too. I think you'll be pleased with it.....
I've had my Mars since 99'. No complaints. Lots of adjustability, comfortable - with the wheel drop kit. Plus, if I do upgrade, it would be to the Helios, so I could just transfer the spektrum system right over.
If you compare the Mars to the Helios, you'll find that the Mars has at least 80% of the Helios' menu features.
This is true. And along those lines, I only use 20% of the adjustments that I have now!
Then there is the supposed speed factor. The Helios claims to be faster than the original Mars. However, the Spektrum module claims to trump them both.
Have any of you noticed a difference in responsiveness after switching to the Spektrum?
I'll tell you on friday after practicing, I have all the "Ko goodies" so I'm running in AHRS mode ...I have 2 cars, one with the KO recvr, one I just installed the spektrum in and will be running both, setup exactly the same and see what the lap times/response, etc... is, from what I understand the speed differences "on paper" are something that mere mortals wouldn't be able to detect ....we'll see
