New Tekin Gen 2 RS and RSX >
Old 08-12-2013, 10:52 AM
  #181
Team Tekin
Tekin Prez's Avatar
Originally Posted by Barry_Hughes View Post
can anyone help with understanding the data logger throttle graph.
Set the Gen2 with my Sanwa Exzes transmitter/sanwa RX-451r receiver.
Neutral OK set throttle & brake - all lights flash to show hitting maximium.
Download the data and the throttle highpoints show 82.21.
Change the EPA's to 140% (Max) reset the ESC and try again, hit max throttle all lights flash.
Download the data throttle highpoints on graph show 121.21.
So it seems the throttle highpoints are always 18 below what the EPA is set at.
Is the highpoint on the graph wrong or I am not hitting full throttle even though all the lights are flashing?
The short answer is that it does not matter because we calibrate to the end points and neutral so they are correct and you get full throttle and brake.
The technical answer is because the standard signal pulse width for RC systems is 1.0ms full brake, 1.5ms for neutral, 2.0ms for full throttle. Our scale is based on these numbers 100/-100. Some radios are 50/50 and some radios are 70/30 and move the neutral down to 1.3ms to give you more resolution on the throttle side.
With your EPA set at 100% the radio appears to be giving us around 1.9ms for full trigger. When you increase the EPA to 140% it is giving us around 2.1ms for full throttle. In either case we will flash all the leds and give full throttle/brake if we are calibrated to the radio output.
Sidenote... some radios will drift as batteries get low or due to sitting in hot sun. You can radio calibrate and then turn the radio EPA up 5 or 10 to make sure you always get to full throttle.
Tekin Prez is offline
Old 08-12-2013, 12:19 PM
  #182
Barry_Hughes's Avatar
Thumbs up
Thanks for the reply
Barry_Hughes is offline
Old 09-08-2013, 08:15 AM
  #183
Reese Bobby's Avatar
Hi All,
Sorry if you answered this before, here it goes anyways. I would like to know when the RSX or RS Gen 2 Pro is estimated to b released? I am trying to plan a head a little and would like to run the new ESC.
Thanks.
Reese Bobby is offline
Old 09-08-2013, 10:53 AM
  #184
Odin544's Avatar
Trader Rating: 93 (100%+)
There is no estimated release date.
Odin544 is offline
Old 11-15-2013, 10:05 AM
  #185
Team Tekin
Randy_Pike's Avatar
Here's a "How to" of the data logging. HOw to use it, what to look for and changes that can be made to the car to lower your lap times.
http://www.teamtekin.com/manuals/TWS...wTo_111513.pdf
Randy_Pike is offline
Old 11-15-2013, 06:55 PM
  #186
Csaari77's Avatar
Trader Rating: 34 (100%+)
What's the word on the Android app? Is there a release date yet?
Csaari77 is offline
Old 12-26-2013, 06:47 AM
  #187
nitrobeast's Avatar
Trader Rating: 42 (100%+)
Very nice write up!
nitrobeast is offline
Old 01-09-2014, 10:25 PM
  #188
Just curious what are the differences b/t the Gen 2 and Gen 2 pro? Apologies if this has been answered, I scanned the thread but didn't find an answer. I'm guessing Gen2pro will be able to handle lower turn motors (edit).
cheers
Obsidian is offline
Old 01-09-2014, 11:04 PM
  #189
RedBullFiXX's Avatar
cheers
What is a Gen2 Pro ?
RedBullFiXX is offline
Old 01-10-2014, 09:11 AM
  #190
Skitee's Avatar
cheers
I suppose you could call the RSX the GEN2 Pro since there is no Pro in the RS GEN2 line. I believe it's rated to a 2.5 turn (540) on 2S in 1/10 on road
Skitee is offline
Old 01-20-2014, 11:52 AM
  #191
theproffesor's Avatar
Trader Rating: 59 (100%+)
Ok so my data logging is acting odd. When I first ststing looking at it it would log everytime I turned the ESC on, even if it was only a few seconds. Then I realized it would only store 12 runs so I deleted them all. Now it will only store one run at a time and only 4 or 5 minutes of a run. Also the run it stores is the last one after a delete. Not necessarily the one that just happened. I would like to get back to the way it was. That way I could watch and compair a whole race day. Also an entire 8 min run so I can see batt voltage at the end of a run.
What did I do to my RS SPEC?
theproffesor is offline
Old 01-21-2014, 10:10 AM
  #192
Bump for an answer
Old 01-21-2014, 10:46 AM
  #193
Moderator
Clegg's Avatar
Check out this link for some details on how to use the datalogging feature:
The data log capacity in the ESC is only based on raw data capacity not run counts. So if you have one 5 minute run, logging at .1sec, and all of the data counters (RPM, Throttle, ESC Temp, Motor Temp, and Voltage) you will only see 4 or 5 minutes of data for one run only. Once the datalog is full, no more gets written to it. It would be nice to be able to set an "overwrite" bit so that it just keeps the last 5 - 10 minutes of data, but that's not how this version of the software works currently.
The way to get a full 8 minute run would be to raise the time interval/resolution to .2 sec (or higher), and remove data points you don't need. Like throttle, that is a nice one to understand where on the track you are in relation to RPM (correlate if you are full on the throttle and how the RPM curves from that), but once you are used to a track you don't need that counter. Disable it by unchecking it when you are looking at a dataplot. That will save that setting to the ESC in real time (If the ESC is connected to hotwire).
I also reset my Gen 2 RS and RSX ESC's data log right before I drop the car on the track. I just reach in and hold the INC button until it beeps at me.
Also, you can tap the INC button and it will show you on the LED's how much of the datalog is full.
Another tip is to save the datalog from one run to your PC and then you can wipe the ESC, and run again without worrying about losing the first runs data. You can then open multiple datalogger windows in Hotwire and compare multiple data plots.
But in the end the short answer to your question is, log less, and less often and you can get 8 - 12 - 15 minutes of logging on the ESC.
Clegg is offline
Old 01-21-2014, 10:49 AM
  #194
Moderator
Clegg's Avatar
One thing I also want to mention is the Tekin Gen 2 RS Spec that I am using in 1/12 right now works great with a booster and logs as expected. I can see the datalogs of the 1S battery voltage and everything like normal. The wiring and configuration for the Tekin Gen 2 hardware is the same as the RS when it comes to a booster and 1S running. And if you notice in the pic below, the Tekin Spec ESC is so light I had to actually had 10G of weight to that side of the car. Which is great because the weight is low, and I can place it where I want.
This is the car and setup I'll be running at ROAR Nats in Omaha for 17.5 1/12.
Clegg is offline
Old 01-21-2014, 11:07 AM
  #195
Moderator
Clegg's Avatar
FYI, I updated the thread name to be more accurate and cover not only the Gen 2 RS but the RSX as they are shipping at the end of the month (per A-Main's website).
I also wanted to post that I've been running the RSX in mod touring a bit in the last week, and have been very impressed. Earlier posts in this thread mentioned concerns about temperature and the need for an aluminum case. Well the RSX has a very nice aluminum case, and heat is not an issue.
I accidentally tested the capabilities of the ESC to reject heat, I forgot to plug in the fan after changing a setting with Hotwire. I ran a 5 minute qualifier with a Tekin 6.5 motor, and a fair bit of boost thrown at it. With the fan on the ESC, but not running, at the end of the run the ESC was only 140F (according to the datalog, my temp gun on the case showed it at 125F). That is a very cool running ESC for how much power was taken out of the battery and how fast the car was. On runs with the fan on the ESC and running, it comes off the track at 120 or below in the datalog and about 110 on the case itself. No worries about overheating this ESC!
Clegg is offline
