New Tekin Gen 2 RS and RSX >
Old 06-07-2013, 08:08 PM
  #136
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by valk View Post
What about the pro replacement? I need new esc for winter.
Tekin Prez posted in another thread they are testing them in mod TC's now. I'm in the same boat. Would like to have one for my 4wd mod buggy(now) and will need it for my mod TC come winter time.
I'm sure they would love to release it today. But why release something if its not up to their level of satisfaction yet?
Odin544 is offline
Old 06-08-2013, 01:20 AM
  #137
mutley001's Avatar
When will the RS gen2 be available in the uk? Any ideas?
mutley001 is offline
Old 06-08-2013, 10:00 AM
  #138
valk's Avatar
I woukd have been all over a gen 2 if i diidnt blow my nitro up heh. Want a pro lvl esc for all applications 1s/mod. The booster never bothered me about thr rs. But rs pro thermaled way easy with a 4.5.
valk is offline
Old 06-09-2013, 02:16 AM
  #139
TrevCoult's Avatar
I don't have an exact date but I've heard it won't be long now. You won't be disappointed, I'm very impressed with mine.
Trev
TrevCoult is offline
Old 06-09-2013, 03:05 AM
  #140
jsr555's Avatar
Trader Rating: 17 (100%+)
What's the recommended running temps for the Gen2 motors. I've been running my 17.5 at about 140 but up'ed the motor timing and gearing the other day. It is now running about 160 - 165. That should be fine shouldn't it.
jsr555 is offline
Old 06-09-2013, 03:56 AM
  #141
mutley001's Avatar
Trev
Where did you get yours from Trev?
Old 06-09-2013, 12:43 PM
  #142
Odin544's Avatar
Yeah thats perfectly fine. Tekin recommends keeping them under 180 degrees F. I like to keep mine around 160.
Odin544 is offline
Old 06-09-2013, 08:33 PM
  #143
bvoltz's Avatar
Trader Rating: 44 (100%+)
WOW!!! the new software for the data logger is GREAT!!!! I know more improvements are coming but that ability to save and pin point on the graph was great...
I do think the ESC Temp and Motor Temp are crossed on the graph, mine was showing the speedo at 150 and the motor at 74... and yes I did make sure it was using English...
bvoltz is offline
Old 06-09-2013, 11:46 PM
  #144
TrevCoult's Avatar
I got it direct from the USA. (Tekin headquarters to be exact!)
Trev
Old 06-11-2013, 01:34 PM
  #145
bvoltz's Avatar
To the folks at Tekin.
With the data logging, how many minutes of on time (not run time) can be recorded? per sample rate setting....
What I noticed is the I used the default sample rate, it was not getting the full 6 min run (remember 6 mins in the run is not the same as 6mins on for the speedo. You have warm up of a say a lap, then waiting on the start, then if you are last, waiting until your are called on the clock), it would stop before the run was over.
bvoltz is offline
Old 06-11-2013, 02:14 PM
  #146
Team Tekin
Tekin Prez's Avatar
At max sample rate of 10 per second and all 5 graphs turned on you only get about 3.5min of run time. At sample rate 5 you get double that. Turn off a few graphs and you get a few more minutes pending which ones you turn off. The temp graphs use the least memory. The rpm uses the most. With just the temp graphs on and the lowest sample rates you can record a long time.
Sitting idle does not take as much memory. It is roughly 1/10 and it can sit idle for around 30min, or looking at it another way it can sit idle for 3 min and still have 90% memory left for driving.
Always best to press and hold incr to erase all data immediately before a run you want to record.
Tekin Prez is offline
Old 06-18-2013, 04:48 PM
  #147
bigblok427's Avatar
Default gen2 for 1s
Question can we use the gen2 1s with a booster like the original rs thanks..
bigblok427 is offline
Old 06-18-2013, 10:55 PM
  #148
Odin544's Avatar
Yes it will work with a booster or rx pack plugged into the rx.
Odin544 is offline
Old 06-19-2013, 10:54 AM
  #149
Anyone knows if the Tekin Rs2 can read motor temp on a Revtech motor or a Novak Vulcan ?
Shock Tower is offline
Old 06-19-2013, 01:06 PM
  #150
Team Tekin
Randy_Pike's Avatar
Not sure on either of those motors. It all depends on whether or not they included the temp sensor.
I'm sure they'd know if you asked them.
Randy_Pike is offline
