Step Charging????
#16
That profile works excellent with 3300s .
#17
Re: Re: Step Charging????
Originally posted by sweet wasabi
I will help ya
I will help ya
is that 6 per cell? or did you put 60 per pack? i'm confused.
i am using vtec 3700s (int 3700s) and currently using 8m/v per cell.
i am going to give that setup a try but need help on the m/v, because i'm confused
#18
Re: Re: Re: Step Charging????
Originally posted by raving-monkey
i'm not sure what m/v you mean.
#19
i am using the orion advantage...and yes it does have temp cutoff.
#20
I will try this profile next week.
CTX Mode for Intelect 3600
Stage 1st 2nd 3rd
Charging Amp 6.5 A 0.1 A 5.2 A
Capacity 3100 mAh 3120 mAh 3900 mAh
Flex Setting off off off
Delta Peak 12mV (6cell)
Temp Cut 48Deg
Repeak 2 times Delay 5 min Repeak Capacity 250mAh
This Setting is based on Cold Temperature.
#21
#22
yes, I also have the same profile - awesome results with my GP3300.
Stage 1st 2nd 3rd
Temp Cut 48Deg
Stage 1st 2nd 3rd
Temp Cut 48Deg
#23
12mv for the pack is fine, 12mv per cell is crazy +)
I use 30-36 mv per pack myself, on re-peak I use 10mv per pack
#24
my packs will get around 120F (49C).
the temp cut-off will protect your pack not to get overcharged! on Step3.
#25
Oh, in winter time when the temparature is cold -> always use the warming tray and heat it up to 26 to 28C at least before charging!
#26
well, no point setting it to 12mv per cell, if your packs are triggering temp cutoff that low, you are probably getting nowhere near 12mv/cell anyways
#27
#28
12m/v sounds crazy high....what temp do your batts get to when its cold?
Do any of you remember seeing a certain pic of hara's pit area at some large event last year where hara had some mysterious tray that he placed his battery in during charge? This was a warming tray. You have to believe he was doing this for a reason .
#29
ok, I just saw what Arun mentioned !
fan and heatsink on the left of Marc.
