Like Tree24Likes
Old 07-28-2013, 07:30 PM   #301
Trader Rating: 20 (100%+)
Originally Posted by jag88 View Post
Does anybody here use rotor size as a tuning aid ?
Kind of. Well, I've changed rotors but not for different track conditions or layouts just to get the power smoothed out for my driving. I run on a larger outdoor track and use the LRP X12 4.5t which is a bit of a monster in the low to mid rpm range. I ran it last year with the stock 12.5mm rotor. This year I changed to the 12.0mm rotor and it's much smoother with more top end power. Definitely a great change for my track and my driving on the infield.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-02-2013, 02:30 PM   #302
SamuraiJack's Avatar
Trader Rating: 38 (100%+)
Default Braking adjustments
Anyone wanna talk specifically about what types of braking-related adjustments they made to deal with all the speed/power of modified setup (EXPO on transmitter, ESC brake settings, other)?
SamuraiJack is offline   Reply With Quote
Old 08-02-2013, 02:50 PM   #303
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I think between 10 and 25 on drag brake is pretty standard. I turn my push brake all the way up in the esc and then get the amount of brake I want on the radio. I don't use any expo or abs etc.
Old 08-02-2013, 07:46 PM   #304
jag88's Avatar
Thanks for the reply.
Exactly what I was thinking. I'm looking for a smooth power delivery off the corner in the infield. The track I race on is huge and unprepared and putting the power down from a 4.5 Reedy is a challenge.
jag88 is offline   Reply With Quote
Old 08-04-2013, 05:43 PM   #305
How do you get it on the radio? Throw?
Old 08-04-2013, 05:49 PM   #306
B00t13g's Avatar
On a ko it's brake travel or EPA.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 08-05-2013, 03:17 AM   #307
On my Eurus I think its called brake high point. Of course it differs for every radio. On mine on med grip carpet I set the esc to 100% and calibrate the esc with the brake highpoint set to 100. Then I turn it down to 80-85% usually.
Old 08-05-2013, 01:01 PM   #308
Travel, that's what I meant, yes. But if you only decrease travel, then you eliminate your max brake % right? I guess if your racing if you a braking 100% you are also losing
Old 08-09-2013, 12:27 PM   #309
Default Keeping it straight
Would anyone like to provide some tips on keeping a TC straight while blazing down straight-a-ways? Thoughts that come to my novice mind:
- how to absolutely center servo arm
- minimize play in steering
- minimize chatter
- toe seems to have some affect? depending on grip?
Old 08-09-2013, 12:29 PM   #310
- minimize chatter
what kind of set up are you running? what size motor?
Xray T4, RC10T4.2, RC10B4.1 to 4.2 conversion, Axial SCX10 Jeep, 1/8 ERBE, OFNA DM1 spec E (going for 100mph).
BC2G is offline   Reply With Quote
Old 08-09-2013, 12:35 PM   #311
Trader Rating: 27 (100%+)
- minimize chatter
Toe can make a huge difference. On my car, my rear toe was super off (4 vs 2) and it would cause my car to dart one direction on throttle. Once I fixed that, it helped a ton.
But the number one thing I noticed about getting and keeping the car straight is... The driver! Mod cars have so much power that if you're exiting a corner and you haven't straightened out for the straight, it's really easy to hit a board. I still suck at mod, but I try to not get on throttle until my car has pointed straight.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 08-09-2013, 12:57 PM   #312
- minimize chatter
For centering the steering, on a fresh build, I eyeball everything first to get it close. Then I mess with servo position vs. steering linkage length to find the setup that gives the most even EPAs. Then I measure the tie-rods to make sure they're exactly the same length. Then I put the car on the setup station, center everything by eye, and set camber. Camber has a big effect on toe. Toe has a smaller affect on camber. Then I turn on my radio and adjust sub trim so the toe reading is the same left and right, then re-check camber. Then I set my actual toe and re-check camber again. Then I turn the wheel to each side and check the toe at maximum lock, and adjust EPAs to get them even.
Minimizing play in steering really depends on the car, I think. The plastic bag trick can work well if the ballcups are loose.
You shouldn't have chatter in a straight line.
You didn't mention suspension tweak, which is really, really important. With the amount of toe and camber we usually run, if there's a suspension tweak it will load the tires very differently in a straight line, and make the car pull.
Along those lines, left/right weight balance and droop accuracy are also important, because they can create or mask a suspension tweak.
More front droop can also make the car less sensitive to suspension tweaks and track surface irregularities.
Sometimes the track will just have funky slopes and irregularities, though, and you just have to learn how the car is going to pull at different spots and compensate for it.
-Mike
Old 08-09-2013, 02:40 PM   #313
Spec-r S-1 w/13.5 and 5.54 fdr Savox SC-0254mg.
-Mike
Thanks, lots of stuff to check.
EXPO on steering?
Also, I think I am noticing variation in how the steering comes back to center after turning.
Old 08-09-2013, 09:54 PM   #314
Bishop's Avatar
I actually did some driving for the first time last night with a 5T and boosted Tekin, did so on my home track which is a rather large nitro track, was crazy fast, played with some less or no boost profiles, they did not seem to really give the speed I felt I would need.
Got to say driving a boosted car is like nothing else, any setting you throw on the car seems somewhat overwhelmed by the level of power, can't say I think it was an ounce faster than I get round the track with a blinky 10.5T, but it looks way more impressive.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-09-2013, 11:47 PM   #315
Jochim_18's Avatar
Driving MOD your setup needs to dead on... Right balance all the way around or you will be all over the place... On breaking I usually set the drag break really high without over heating the motor and then turn down the break highpoint on my radio to about 75%-80% enough to stop the car without locking the wheels... Drag break is your friend in MOD it is alot easier to drive the car in the corners... On throttle I set the travel around 30% to prevent wheel spin..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
