Like Tree24Likes
Old 05-01-2013, 01:32 PM   #196
orcadigital's Avatar
Trader Rating: 61 (100%+)
Originally Posted by PROMODVETTE View Post
I don't think motor temp will be the problem, I think it will be my Tekin's temp. The capacitor bank I have is supposed to combat temps, we will see!
To be fair, I think temps will not be an issue while the left half of your car litters the straight, but good to be prepared.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 05-06-2013, 11:42 PM   #197
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
For mod would having a stiffer chassis be the way to go or more flexable? Also what about a top plate? Does anyone use the Exotek chassis?
Josh-n-ya is offline   Reply With Quote
Old 05-07-2013, 12:09 AM   #198
Trader Rating: 60 (100%+)
Everyone should know the only thing broken (well not even broken) ended up being a spur gear. In my excitement to get out and play I didn't double check the mesh and chewed one up! Quick fix was to smash the motor into it and run at low rpm to create new "teeth" and go out and run it some more
PROMODVETTE is offline   Reply With Quote
Old 05-07-2013, 03:02 PM   #199
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Question I have no ideal..it is there somthing you have to set your radio for mod 4.5 in TC?
It Is drag brake is require? if so How much? I have the SXX TC for esc...Thanks
OVA is offline   Reply With Quote
Old 05-07-2013, 03:31 PM   #200
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I ran between setting 3 and 6 on that speedo with the v4.0 software with a Reedy 5.0 when I ran it indoors on carpet. I think I like a little more drag brake than most though.
Old 05-07-2013, 04:20 PM   #201
OVA
OVA's Avatar
3 on power profiles and 6 on Initial brake ??
I'm not sure what software in this esc has...
Old 05-07-2013, 04:28 PM   #202
Trader Rating: 20 (100%+)
You'll want to know which it has because there is a big difference between the settings from one to the other. If you have the 4.0 software you will only have 0-6 on the boost setting and that is the version you want. if you have v1.5 then boost will go from 0-10 and you should consider putting 4.0 on it.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 05-07-2013, 04:52 PM   #203
95lscoupe's Avatar
Im running a Sxx Ver 2 with the new board form Lrp and i believe that they have the 1.5 software on them.Im running mod tc with a 5t x20 what would putting the 4.0 software on the esc do and is it worth spend the $30 on the link setup?
Matthew Abey
Awesomatix USA/Speedzone USA
LRP/Futaba/Middle River Russian Mafia
Awesomatixusa.com/Speedzoneusa.com
95lscoupe is offline   Reply With Quote
Old 05-07-2013, 05:21 PM   #204
OVA
OVA's Avatar
Hey troy
I have the V1.5 software because of the 0-10 on the boost setting ..
question how can you tell the differnt bteween the new board and the orignal SXX TC V2?
Old 05-07-2013, 05:29 PM   #205
95lscoupe's Avatar
Hey troy
The old board will step up the voltage to 6v when running 1s the new one will not thats the only way I know of telling the diffrence.
If you have the old board id recomend sending it in to get it replaced the bec goes bad in the old board quick and its a free upgrade.
Matthew Abey
Old 05-07-2013, 08:00 PM   #206
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Does brands of motor matter in mod? (onroad asphalt)
is 64 pitch or 48 pitch common in asphalt mod?
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 05-07-2013, 08:13 PM   #207
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Definitely! All the brands have a different feel. Some are more smooth, others have a more aggressive powerband.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 05-07-2013, 08:23 PM   #208
Mugen10's Avatar
Ok, that changes my search for motor. So how do you find a smooth feel motor vs. edgy motor?
Xray T4
Old 05-07-2013, 08:32 PM   #209
I'd say besides LRP motors most all them are pretty smooth. The reedy motors are a popular choice, kind of a happy medium.
Old 05-07-2013, 08:37 PM   #210
purple haze's Avatar
I am in the same situation .
I started racing stock TC in Sept and then Mod TC with a boosted 10.5 in December . So I am a relative noob still I guess . I was thinking about trying a 5.5 this fall when onroad gets going again around here , but am not sure what I should be looking at buying . Any recommendations for me ?
www.karz.ca
www.carcar.ca
www.rcgears.net
purple haze is offline   Reply With Quote
