Old 03-18-2013, 09:18 PM   #1
alcyon's Avatar
Default Gear Diff maintenance
I have Tamiya white TRF 417 gear diffs which i purchased 6 months ago. I am using #300000 oil in the front and used #900 for the rear a few months back and now am using #3000 for the rear. However i find that after a few runs, oil leaks from the sides of output shafts , only for the rear diffs.
I took the rear diff apart and think i found the problem. The o rings for the output shaft is gripping the shaft tightly, but the o-ring itself is rotating inside the gear diff housing. I was thinking of putting some silicone sealant in between the o-ring to prevent it from rotating, which i beleive is the cause of the oil leaking from the out drives. Any thoughts from the more experienced members?
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 03-18-2013, 10:26 PM   #2
B00t13g's Avatar
Replace the o rings.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-18-2013, 11:45 PM   #3
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
What he said and also put some associated green slime on o-rings before installing.
Josh-n-ya is offline   Reply With Quote
Old 03-19-2013, 06:56 PM   #4
alcyon's Avatar
Thanks Josh, i always put green slime on but doesnt seem to help for long, its supposed to keep the friction low between the outdrive and the o-ring. But somehow the oring still spins. I am not too sure how long will a new o ring last, but some racers i know said they put some clear soft silicone sealent on the outer part of the oring that fits into the case. I did it last night and it should cure completely by tonight. lets see if it works or not.
Old 03-19-2013, 09:39 PM   #5
SS LS1's Avatar
Trader Rating: 23 (100%+)
Alcyon, let us know how it works out for your using the sealant to hold the o ring in place. I have read of guys carefully CA gluing the outer o ring edges into the diff housing to accomplish the same thing you are trying with sealant.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 03-19-2013, 10:59 PM   #6
narcotiks's Avatar
Kyosho 5mm orings will solve all your issues
narcotiks is offline   Reply With Quote
Old 03-20-2013, 02:18 AM   #7
alcyon's Avatar
hmm good idea. i may resort to that if this doesnt work.
Old 03-20-2013, 03:27 AM   #8
zzztech is offline   Reply With Quote
Old 03-20-2013, 06:29 PM   #9
alcyon's Avatar
I am glad to report that the 24 hour silicone cure works..so far, i inserted the outdrives into the diff housing while pressing a SMALL end of the box wrench against the o ring, as a precaution to prevent it from coming out. After that i spin the outdrives ..and the o ring doesnt turn at all. Oh yes, i did put on green slime. However, the friction between the outdrive and o ring is higher now, so to compensate, i use the #900 oil that tamiya supplied with the diff set. Its too early to tell now if the diff will not leak becuase i have not tested it at the track yet, but so far seems to be holding up.
Old 03-20-2013, 10:12 PM   #10
SS LS1's Avatar
Do you happen to have a part number buy any chance?
AE SC10 4x4
AE SC10 AE B4.11
Old 03-21-2013, 12:03 AM   #11
narcotiks's Avatar
From memory i'm pretty sure its ORG 05.
Old 03-21-2013, 02:26 PM   #12
SS LS1's Avatar
Thumbs up
Thanks, I think I found them.
AE SC10 4x4
AE SC10 AE B4.11
Old 03-23-2013, 09:30 PM   #13
I glue the o ring and it definitely stopped most of the leakage.. Spec r gear diffs work but as far as I know everyone that has used a spec R diff had leaking problems
JOE SI is offline   Reply With Quote
