Old 05-05-2005, 01:59 PM   #1
Default Gearing of a 19 turn spec motor
I am making the switching from 27 turn to 19 turn in my touring car. Can anyone give any advise if I need to gear up or down on the 19 turn?
pcmlc is offline   Reply With Quote
Old 05-05-2005, 02:00 PM   #2
ddesros2's Avatar
Gear it the same as a Monster Pro to start. Go up or down a tooth as needed (size or track, etc..)
ddesros2 is offline   Reply With Quote
Old 05-05-2005, 02:00 PM   #3
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
you gear up and it depends on the track size you should try asking someone who runs 19t where ever your racing and ask them what final drive are you running and you will know what pinion you should get
Roberto Falcon is offline   Reply With Quote
Old 05-05-2005, 02:01 PM   #4
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
in my expeciences i would go up a tooth or two when going from stock to 19t
Javen13 is offline   Reply With Quote
Old 05-05-2005, 02:01 PM   #5
John Tag's Avatar
Trader Rating: 42 (100%+)
Most 19 T motors are 3t higher in 64 pitch, C2 roll out around 31 mm Reedys are even higher. Hope this helps.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 05-05-2005, 02:02 PM   #6
it also depends on what motor he is using the quad mag always likes to be geard high
Old 05-05-2005, 02:04 PM   #7
Which motor and in what car?
Charles is offline   Reply With Quote
Old 05-05-2005, 02:08 PM   #8
By the way i see your from NC and i was wondering if theres any tracks near Apex or Raleigh area?
Old 05-05-2005, 04:22 PM   #9
edseb's Avatar
Wow, some interesting comments, but the experience I've noticed with most guys with quad mags is final gear ratio of 6.0 + or - a tooth depending on track, that of course is with rubber.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-06-2005, 07:02 AM   #10
Default Gearing of a 19 Turn Spec Motor
Thanks for all the data. I should have told you that I am running an Xray with a Trinity Chamelon motor. The track is a 13 turn asphalt track with 2 (80') straight aways. Lap times are 18 seconds in stock. Information from competitors is they are running 6.9 to 7.2 on the stock motors.
Old 05-06-2005, 07:10 AM   #11
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
That sounds about right. We run on a 130 + foot straight asphalt track and we are running 6.4 to 6.6 with a C2.
On element 19t. we run anywhere from 5.9 to 6.1 fdr.
Almost the same on a reedy 19t. too.
Asphalt on rubber tires.
EA Motorsports
picco007 is offline   Reply With Quote
Old 05-06-2005, 07:11 AM   #12
Default 19 Turn motors
John I have sent you a pm. I need another motor
Paul
Old 05-06-2005, 07:28 AM   #13
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Paul, How's the car working out? Glad you're enjoying eXpress motors!!
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 05-06-2005, 07:40 AM   #14
Default Xray
We struggled a bit on carpet and got hammered in the B-main two weeks in a row and broke a c-hub and hub carrier. I really like the car and this will be the first weekend on pavement. I switched over to the other chassis, as I don't want to scratch up the perfect BMI chassis.
If you have the information available could you pm me some basic pavement chassis data. I plan to get another motor from Tag. I see that he picked up Brandon as a team member. Nice guy and very good driver.
Paul
Old 05-08-2005, 08:38 AM   #15
I'll send you a PM with a setup I would suggest using that BMI adjustable upper deck.....you can dial in the flex of the car with it and it's a one of a kind piece
PEAKRACING DYNASTY 19 TURN SPEC MOTOR hook6905 R/C Items: For Sale/Trade 5 06-13-2008 09:02 PM
Best gearing for Komodo Dragon 19T spec Pro motor? Porkibear Electric On-Road 29 07-20-2006 11:44 PM
what is the best 19 turn motor (not spec) Apple Electric On-Road 46 02-03-2006 12:27 PM
Gearing issues - HOT motor (reeddy 19t spec.) Captjono Electric On-Road 23 04-03-2005 07:24 PM
Reedy 19-Turn Quad Mag Spec Motor Hebiki Electric On-Road 14 12-28-2004 03:19 PM
