Old 03-17-2013, 02:13 AM   #1
Default Tire warmer power supply?
I ordered me a GT Power tire warmer and am wondering what kind of power supply to use with it as the online specs are really useless. Would a regular 12-15v laptop power supply be sufficient?
13art is offline   Reply With Quote
Old 03-17-2013, 05:32 PM   #2
This one?
http://www.rcmart.com/power-gtpw-con...l?cPath=35_292
It looks like it comes with everything.
-Dutch- is offline   Reply With Quote
Old 03-17-2013, 06:05 PM   #3
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
you could put s3 lipo inside
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 03-18-2013, 04:17 AM   #4
Yeh that is the one I was talking about. Was just wondering as I have a laptop power supply sitting around and don't want to buy a battery/power supply if I don't have to
Old 03-18-2013, 05:41 AM   #5
Matthijs's Avatar
Specification:
•Dimension: 170mm(W)x 120mm(D)x 57mm(H) (Control Stand Only)
•Net Weight: 360g
•Input: DC7.2~15V
•Temperature Range: 20~80°C, 100°C
•Buttons: 4
so yes, your laptop supply is sufficient
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 03-18-2013, 05:59 AM   #6
Are we talking about the simple brick type laptop charger thing?
How can you convert that to some alligator clips or something like that?
Cheers
"No matter if you win by a inch or a mile, winnings winning".
AleD123 is offline   Reply With Quote
Old 03-18-2013, 06:54 AM   #7
Skiddins's Avatar
It's the amount of current the power supply can supply that really matters.
A set of Much More Digital tyre warmers draws around 6.5A when first turned on, once up to temperature that drops to a few amps.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-18-2013, 10:10 PM   #8
yeh i was wondering about the current draw as if it was low then i can use a laptop brick power supply as they can supply enough current if its just 6.5A. i wouldn't use the alligator clips, just simply cut the wires and change the plug over.
