Old 05-31-2005, 02:52 AM   #61
TryHard's Avatar
Wyd, yes it uses the 950 bearings... however I've had no problem with them since switching to alloy rear hubs. It seems that the plastic hubs on the LWT suspension just allow the bearings to move too much, which knackers them.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-31-2005, 05:45 AM   #62
Burlap's Avatar
Send a message via MSN to Burlap
So does it use the driving shafts/unis from the LWT suspension?
The more I read about it, the more I want it (I run tarmac mainly). However only have the standard 415.
Burlap is offline   Reply With Quote
Old 05-31-2005, 08:47 AM   #63
TryHard's Avatar
yup, uses all thoose parts form the LWT you mention.
Old 05-31-2005, 09:18 AM   #64
AdrianM's Avatar
Originally Posted by linger
TTT,
I got my Promodule set last night.
Looks great!
The included red springs averaged at 6.42 lb/in
I don't have the Tamiya spring set yet, so I dug through my old ancient HPI spring sets (pro1 and pro2 era) and measured them.
Measured values
HPI Gold #6826 10.28 lb/in
HPI Silver #6825 8.35 lb/in
HPI Blue #6847 7.78 lb/in
HPI Red #6844 6.05 lb/in
The HPI gold and silver are measuring close to what the HPI site specs them out to be. However, the HPI site isn't even in the ballpark with their blue and red springs. They are supposed to be 14.8 lb/in and 13.3 lb/in respectively. I wonder what they were smokin?
Xtreme R/C Cars just did a big spring test article. Your findings (actual rates don't match advetised rates) are pretty normal. The really shocking thing is the discrepancy you can find in pairs or springs! Ray Speed and Schumacher are the only companies whos rates are correct and have closely matched pairs.
Adrian Martinez
Old 05-31-2005, 12:53 PM   #65
stonedgti's Avatar
Trader Rating: 15 (100%+)
If anyone is looking for a set. Please PM me. i have a 2 race old pro-module suspension.
$55 shipped. Sold!
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 05-31-2005, 01:37 PM   #66
dyaz21's Avatar
Wink
stonedgit YGPM
dyaz21 is offline   Reply With Quote
Old 05-31-2005, 02:36 PM   #67
Send a message via Yahoo to GTIRACER
$55 shipped. Sold!
why are you selling it already??? Doesnt meet the hype?
GTIRACER is offline   Reply With Quote
Old 05-31-2005, 05:44 PM   #68
stonedgti's Avatar
It works great, but the LW suspension isn't bad either. Need to sell it to get some new batteries.
Old 05-31-2005, 06:01 PM   #69
Kevin CBR's Avatar
To put on a regular 415, you will need the 2.6 x 25mm shaft that holds the hub carrier to the A-arm P/N 51099, the 46mm swing shaft P/N 53724 aluminum or P/N 51092 steel, EVO IV wheel axle P/N 51094, Universal drive shaft joints P/N 53500, 5x9 bearings (x4), and then use extra spacers on the hinge pin to take out slop. The 415 uses a 48.5mm hinge pin, the lightweight MS version hinge pin is only 46mm and the DJ arm is designed for the 46mm hinge pin on the EVO IV and 415MS.
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 05-31-2005, 06:15 PM   #70
TryHard's Avatar
works fine on the 48.5mm hinge pin ... helps to have a have extra shims around though
Later
Ed
Old 05-31-2005, 08:31 PM   #71
Burlap's Avatar
Are the bearings used in the uprights in the DJ suspension the same size or bigger/smaller than the ones used in the standard 415 uprights?
Old 05-31-2005, 10:29 PM   #72
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Dec, they've said a few times now that it uses 950 sized bearings, which are the same as the LW suspension. The older suspension (TA04 style) used the 1050 bearing, which is a bit bigger.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 05-31-2005, 10:36 PM   #73
Burlap's Avatar
I didn't know the size number for the standard suspension, Simmo
Ok, smaller, so I have to get more bearings as well.
Old 06-01-2005, 08:20 AM   #74
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
Anyone know when Speedtech, All-Speed hobbies or Ultimate Hobbies will have these in stock?
atomic80 is offline   Reply With Quote
Old 06-01-2005, 11:39 PM   #75
Trader Rating: 22 (100%+)
ultimate still has them in stock...they had 8 sets when i was there today.
littleZEN is offline   Reply With Quote
Tamiya "DJ" Pro-Module Rear Suspension System OVA Electric On-Road 14 10-19-2016 01:53 PM
Tamiya Pro Module Rear Suspension AWK Electric On-Road 2 07-26-2007 06:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Tamiya "DJ" Pro-Module Rear Suspension System MDawson R/C Items: For Sale/Trade 1 10-24-2005 12:54 AM
Tamiya "DJ" Pro-Module Rear Suspension System acutts R/C Items: For Sale/Trade 2 08-19-2005 05:59 AM
