Old 05-05-2005, 12:01 PM   #16
Thai3g_Eclipse's Avatar
Are there any online retailers selling it? I haven't seen it anywhere...
HPI Savage Flux HP | Tamiya TB-03
Thai3g_Eclipse is offline   Reply With Quote
Old 05-05-2005, 12:15 PM   #17
Arun's Avatar
speedtech has them now...edit-now out of stock already!
http://nexusracing.com
Arun is offline   Reply With Quote
Old 05-05-2005, 02:54 PM   #18
Old 05-05-2005, 03:04 PM   #19
Be sure to buy lotsa spare arms...
Those things look weak...
MartynD is offline   Reply With Quote
Old 05-05-2005, 03:17 PM   #20
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Originally posted by Smoking motor..
Ed can I have a look at it when you come up to sharley.
It looks like it will stop the car rolled by bumps and kerb riding and stop the camber change as much when it rolls through a corner. It probably design to keep the camber at a fixed angle going over bumps, and massivly reduce the camber change in a corner without having to use harder springs. If the top link was'nt used it could run a fixed camber angle through out compression.
It 's intrestring I give yer that but it a whole new ball game for setting up the supension
The camber control is the same as on all other independent a-arm suspesions, the only change is the more direct wheel rate, not having to account for the leverage of the a-arm.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 05-05-2005, 03:21 PM   #21
TRF415boy's Avatar
Ever seen weak aluminium arms ?
TRF415boy is offline   Reply With Quote
Old 05-05-2005, 03:21 PM   #22
TryHard's Avatar
I doubt they are weak.... being made of alloy... plus going on some posts made by david and a few of his testers, they deffiently aren't.
Guess I'll get too see myself next week
| THard.co.uk | Xray | MuchMore |
Old 05-05-2005, 03:23 PM   #23
Since the arms are alloy, wouldn't that add quite a marginal weight to the back?
Old 05-05-2005, 04:02 PM   #24
NVisible's Avatar
those look quite impressive. How long until other companies follow suit?
NVisible is offline   Reply With Quote
Old 05-05-2005, 04:10 PM   #25
Francis M.'s Avatar
this is something new and interesting. I'm wondering how different it is as far actual feel on the track. i don't think the alum hubs will add that much weight.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 05-05-2005, 04:16 PM   #26
hugh janus's Avatar
as with almost every other product (out of stock)
hugh janus is offline   Reply With Quote
Old 05-05-2005, 04:19 PM   #27
edseb's Avatar
Aluminum hubs on race cars isn't unconventional and the weight is so minute, it goes unnoticed. Corally, a lot of Schumacher, etc. use aluminum in the hub carrier or c-hub with success. It's much different than using it in arms, shock towers, chassis etc. Plus you have the added bonus of having your bearings true and parts developing less play.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-05-2005, 04:41 PM   #28
ChadCapece's Avatar
Is this just a rear suspension design. Or will be be for front as well?
ChadCapece is offline   Reply With Quote
Old 05-05-2005, 04:48 PM   #29
TRF415boy's Avatar
Only rear, as i understand on the front there just is no room for it, as the wheels needs to be able to steer, you can't have the arms going around the shocks or they'll interfere...
Old 05-05-2005, 04:53 PM   #30
TryHard's Avatar
Actually, i'm not so sure... you could technically mount the shock off the C-hub.
It would be in a similar position from the centerline as at the moment, but als be able to be closer to the driveshat.
Your limiting factor would be the arm itself, as mentioned, clearance on the wheels on lock being the problem.
You might possibly be able to do it with 24mm wide rims... but 26 or larger, I would doubt it.
Tamiya "DJ" Pro-Module Rear Suspension System OVA Electric On-Road 14 10-19-2016 01:53 PM
Tamiya Pro Module Rear Suspension AWK Electric On-Road 2 07-26-2007 06:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Tamiya "DJ" Pro-Module Rear Suspension System MDawson R/C Items: For Sale/Trade 1 10-24-2005 12:54 AM
Tamiya "DJ" Pro-Module Rear Suspension System acutts R/C Items: For Sale/Trade 2 08-19-2005 05:59 AM
