Old 05-05-2005, 02:40 AM   #1
xray racer's Avatar
Trader Rating: 22 (100%+)
Default Drift Guru's:- locked diff???
hey,
im not racing very often at the moment and i was wondering how i should set-up my car.
i have 3 original Xray T1's, one my race car, one my brothers and one a spare.
is it better to have a locked diff in the rear for drifting???
should i remove the front belt completely???
will i do serious damage to the drivetrain when drifting?
can you please give me some advice as to what to do in terms of how to set my car up and what diffs to install etc etc.
im thinking of getting a set of yokomo drift tyres...are they worth it???
please help me out
thanx
robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 05-05-2005, 04:54 AM   #2
GTO2's Avatar
R/C Tech Charter Subscriber
I'm certain i'm not Drift Guru but since no one reply, here goes
Originally posted by xray racer
hey,
no, i use a locked diff in front instead, rear must be tight n smooth. Some use both FR tight and smooth for maximum response. I am using PVC wheel by the way.
what for? RWD as in 1:1 ? Most drifters i know prefer 4WD with more weight up front. RWD won't work with PVC, that
one i know.
Not with PVC you won't. Not sure about rubber though, should be heavier on the drivetrain.
LR weight balance, FR slightly more to F.
Diff as above comment. High gear ratio.
Go Brushless for extra torque .
Medium to hard suspensions, depends on car.
And most important, killer looking bodyshell
please help me out
thanx
robbie
I drift quite a lot and i stick with PVC.
If you can get hold of Black ones, they're the best for tarmac n concretes.
I'm sure there're plenty of drift threads here on RCTech that can provide more in depth info. Enjoy!
driftercentral.com
GTO2 is offline   Reply With Quote
Old 05-05-2005, 05:05 AM   #3
pink pac man's Avatar
i guess i could call myself a drift guru....
yeah lock the front......but leave the rear unlocked
and rwd drifting doesnt work...with any tire..the power to waight ratio is like 100x wat it needs to be for rwd
the people at these drift sites wil be able to help you further..
one10slidesquad
rcdrift.org
rcdori
pink pac man is offline   Reply With Quote
Old 05-05-2005, 05:15 AM   #4
GTO2's Avatar
crazy drift video
driftercentral.com
Old 05-05-2005, 06:25 AM   #5
BrainTeased's Avatar
i have my rears locked and the car feels much more responsive. with the fronts tight.
i use a crappy smartech with geared diffs.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 05-05-2005, 08:11 PM   #6
Send a message via AIM to greencactus3
i have diff,diff in my car. and there is no black pvc, that would be ABS. which is softer than pvc, = more grip= more speed. but i prefer pvc for extra long runtimes.
with pvc, i like really soft springs. oh and a reverseable esc.
greencactus3 is offline   Reply With Quote
Old 05-05-2005, 09:23 PM   #7
dreadful's Avatar
Send a message via AIM to dreadful
Locking the front is always an option, however it is rough on the car but so is drifting in general play around with both to get a feel.
I myself have not drifting an xray so cant really tell you the feel of it.
Drifting an r/c car is different than a real car so no fwd or rwd by itself will not working in drifting as earlier stated you cant shift the weight ratio enough.
My basher is an hpi sprint with super high gearing on a novak brushless that puts out tons of torque tears right through pvc and drift rings but its a messy sport
dreadful is offline   Reply With Quote
Old 05-06-2005, 07:07 PM   #8
xray racer's Avatar
thanx for your help guys
another quick question as im keen to give these pvc tires a go. what size tube do i need to get???
will it fit properly on the rim? standard rims?
do i just use CA to glue it down?
one more,
will i do damage to my motor by drifting??? they get rather hot dont they??? i'll only be using either a 27t stock or a 23t jrm
thanx for your help again
robbie
Robbie Lloyd
Old 05-06-2005, 07:50 PM   #9
2inch works fine. and wrap electrical tape around the rim until the pvc fits snug. then no CA is needed. no the motor wont be damaged as long as you still do the proper maintenence. and for it getting hot, with pvc, if you're gearing isnt way off the chart in either direction, it really doesnt get hot. if it does. check your gearing or for binding.
Old 05-06-2005, 09:35 PM   #10
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Default Drift
i accidently drift my car on race day!!
but i also discover a nice setting to drift.
im using a Ta04 with front 1 way and a type B tamiya tyres.
rear yellow tamiya spring and front red tamiya spring.
heres the trick. just set your radio and ESC to full throttle brake . trust me , you will drift.
KREATOR1 is offline   Reply With Quote
Old 05-07-2005, 02:28 AM   #11
i sudject not getting pvc...instead get abs...its black and its softer so its better for drifting
Old 05-07-2005, 07:07 AM   #12
well first off its which you prefer. and mostly by surface. on really rough concrete, pvc is definitly the way to go. on kinda smooth asphalt id say abs. and on traction compund soaked carpet tracks, even pvc is a little hard to drift it sticks so well. actually need to brake before the turn.
spool-vs-locked diff-vs one way Slippery Dan Electric On-Road 1 10-06-2007 02:11 AM
Locked Diff vs One Way gashuffer Racing Forum 2 06-12-2007 07:49 PM
Anyone tried LOCKED DIFF on GP truggy before? SuperEk4 Singapore R/C Racers 5 04-30-2007 12:08 PM
Shock Oil Guru's: Weight diff between brands? dizzy1 Electric On-Road 5 03-14-2005 09:35 AM
Locked Diff "Spool Vs Std Diff OHBRAD Electric On-Road 1 07-05-2004 12:35 AM
