Old 10-28-2006, 01:16 PM   #781
mach51's Avatar
Trader Rating: 30 (100%+)
i reprogrammed it and it looks like it is working ok, no lunging. Its odd that the directions say a blue led will flash throughout setup but mine has a red led that flashes throughout.
I heard older speed controls will do the lunge thing.
mach51 is offline   Reply With Quote
Old 10-28-2006, 07:44 PM   #782
streetracer745's Avatar
Send a message via AIM to streetracer745
the red light means that you have the automatic brake on. the blue light means that its off. so when you are running, it should slow down faster after you let off the gas.
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 10-28-2006, 10:33 PM   #783
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I bought a used sphere comp from a buddy who's had it since the comp first came out. There was an adendum to his directions taht said something to the efect of
"this unit has a red LED instead of the blue LED deswcribed in the directions. Due to this being one of the first units this is OK and we will fix it in later units"
Just a possibility that the older units don't have the blue LED.
Old 10-29-2006, 01:57 AM   #784
STEALTH's Avatar
Trader Rating: 21 (100%+)
Originally Posted by mach51
well, while my 1 day old sphere system is still at LRP for repairs, I picked up a used sphere competition system. I havent had time to really mess with it, I just programmed it. I noticed something, I turn the radio on, then I turn the speed controller on and it lunges forward just briefly like the throttle is blipped.
yes, I know how to program it.
No, the sub trim is not wrong on the radio, if it were it would continue to go forward.
Radio system is an M11 with Spektrum, failsafe on spektrum is programmed with throttle just at neutral.
anyone experience this with the LRP? Man, my novak was hook up and forget about it...
My buddy's brand new Sphere Comp does the EXACT same exact thing.... Is anyone from LRP going to answer our questions on here or do their customers have to figure this one out for themselves.... AGAIN.
STEALTH is offline   Reply With Quote
Old 10-29-2006, 01:10 AM   #785
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Have you tried emailing LRP directly. :nod 1st club meet for my new sphere comp/4 star and very happy with it so far.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 10-29-2006, 05:46 AM   #786
when is the sphere competition TC SPEC comming out? im keen to run this in my 12th with a 4.5.
also is there anywhere to get the total height of the unit with the fan + heatsink? is it higher than a gtb?
TomB is offline   Reply With Quote
Old 10-29-2006, 08:29 AM   #787
Tom
I wonder if the Sphere TC heatsink and fan are factory installed or we need to install them on our own. The assembly is quite high and it wont fit the 1/12 shell.
azmio is offline   Reply With Quote
Old 10-29-2006, 06:54 PM   #788
Originally Posted by azmio
Tom
yep it looks like it won't fit under a 12th. personally i don't think you needthe fan, maybe just the heatsink at the most and cut a small flap in the bod above the esc that directs air onto it.
i mainly want the TC SPEC as it is beefed up. i am also interested in the "launch control" they advertise is this a new feature for the TCSPEC or is it on the old competition version as well? this is a nice feature for 12th.
Old 10-29-2006, 07:31 PM   #789
tom
i am curently using my sphere comp for my 1/12. No heat sink or fan needed. So far no thermal shutdown occured.
The launch control is something new, never heard of it before for the sphere comp.
Old 11-02-2006, 01:04 AM   #790
smilekt's Avatar
which one ESC is robust or better system from thermal problem , Lrp Sphere Comp or GTB ESC . need help
smilekt is offline   Reply With Quote
Old 11-02-2006, 09:34 AM   #791
AdrianM's Avatar
They are pretty much the same. If you look over the Novak and LRP threads you will see equal numbers of each are running well or blowing up.
I run an LRP Comp since it is a little more compact over all.
Adrian Martinez
Old 11-02-2006, 10:48 AM   #792
James35's Avatar
Yeah, you won't need the LRP heatsink if your running 12th. It's really hard to even get it detectably warm.
James35 is offline   Reply With Quote
Old 11-02-2006, 04:22 PM   #793
Angry
Same thing happened to mine but it went up in smoke. Since I preordered and paid for it from the LHS by the time it blew it was over the 120 days even though I only used it for a month. Sent it to AE in california and was told I would have to pay $114 to get it repaired. Jason there is just an A-hole, I have never dealt with such a rude CSR, don't believe me call him at 714 850 9342 ext 123. Last piece of LRP sh!t I have bought, used to be a big fan till this jerk.
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 11-06-2006, 08:05 PM   #794
smilekt's Avatar
thanks you so much ..
do you already use with 3.5r .. ?
Old 11-06-2006, 08:24 PM   #795
would it be safe to run the 3.5 with a shpere comp? it has a 3.5 motor limit, but would that make it not last as long? i run the 4* which is equivalent to their 5.5 i think, and its insane. im nto sure if you would want something that fast. i mean that would be incredibly fast.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
