Old 05-01-2006, 10:01 AM   #541
Tech Legend
Wild Cherry's Avatar
4 star is like a 7 turn ....
Thats a whole lot of motor...
most likely 3 star or even the 2 star may be a better choice for off-road 4W....
depends on how much traction & the size of track ...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-01-2006, 11:08 AM   #542
What fan/heatsink combo you use with 4 star system in touring? Is it enough 30mm 5v fan + original heatsink?
JanisK is offline   Reply With Quote
Old 05-01-2006, 03:09 PM   #543
lookinco's Avatar
Can I hook up a double Schottki diode to the motor when running in brushed mode?
I am using the original heatsink and the 30mm novak fan in my touring with no problems of overheating.
lookinco is offline   Reply With Quote
Old 05-02-2006, 10:31 AM   #544
Default 12th recommendations
Hi
Which motor would you recommend for running in 12th scale outdoor asphalt? gearing recommendations?
thanks
snowyelan is offline   Reply With Quote
Old 05-02-2006, 03:13 PM   #545
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
I am running the Sphere 3 Star in my 12th scale on outdoor asphalt along with 2 other guys. It has no problems at all. Just becareful in not over gearing the motor.
CarlosG. is offline   Reply With Quote
Old 05-02-2006, 05:34 PM   #546
Mr. McGoo's Avatar
got a problem with my speher competition and 5800 - the sphere has been working flawlessly with my 4300, then this past weekend i popped in the 5800 - and it seemed to work ok in the pit -
i then go place it on the track, make a few turns and it just dies - the amber light comes on the speedo and i have no throttle anymore - i have steering but no motor - i put the 4300 back in and everything is ok...
is there a setting on the 5800 that i need to know about....
any help would be much appreciated....
marc
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 05-02-2006, 06:14 PM   #547
SpeedyPenguin's Avatar
That's a big NO there, the spere is a forward/reverse speed control and it even says in the manual that a schottki diode should not be used with the spere.
Look in the section titled "Warning Notes"
SpeedyPenguin is offline   Reply With Quote
Old 05-02-2006, 06:18 PM   #548
CarlosG.'s Avatar
Mr. McGoo, check the temp of both the motor and esc. If the motor is pulling to many amps causing it to thermal. Also check your sensor wire to see if it does not have a short or a cut in it that might cause it to ground out. That are somethings that come to mind.
Old 05-02-2006, 07:56 PM   #549
lookinco's Avatar
I am running the Sphere Competition which is a foward/brake esc. There are no warming about the double shotki diode in the instruction manual.
Anyone installed one with the sphere competition? Does it make any difference in performance?
Old 05-02-2006, 08:33 PM   #550
CarlosG.'s Avatar
Check under to see if there is a Motor Suppression section like the Sphere has. It would say it there.
Old 05-03-2006, 11:08 PM   #551
CarbonWorks's Avatar
I had a Sphere Comp burn up on me a few weeks ago. I sent it in and they said they looked it over and that it would be covered under warranty. In the meantime, I bought another one since I didn't have anything else to use. Don from associated told me to mount the capacitor under the back of the esc like the manual tells you to do, but to additionally put some servo tape between the capacitor and the exposed power wires underneath. So I did. I was setting my slipper on our porch this evening when smoke began to pour from the speed control again. I had a lipo in ther car, so I was able to very quickly pull out the negative wire. After examining the esc, I noticed that the capacitor had apparantly bridged a few wires underneath the back......through the servo tape. You couln't see it , but when I tried to move the capacitor it felt like it was lightly soldered to the protruding wires. After exposing the cap, I could see where the insulation around it was missing in a small area. I mounted the capacitor in another location away from where they suggest mounting it, and believe it or not the thing seems to work fine. It sure stinks though. So all I'm saying is that the recommended location is for the cap is, perhaps, not the best location.
CarbonWorks is offline   Reply With Quote
Old 05-04-2006, 06:08 PM   #552
Originally Posted by CarbonWorks
I just saw the shaft thing you mentioned tonight on a friends 2 star. It just slid itself out of the can about another 1/2 inch. Only about 6 runs on the thing.
This happened to me today on a 3 star. Was geared right. No crashes, but I bumped the wall twice. Why is this happening?
The motor was brand-new...
Dodgersfan is offline   Reply With Quote
Old 05-04-2006, 08:11 PM   #553
AdrianM's Avatar
You can't use Schottky's on ANY BL speedo when it running in its BL mode. Schottky's are diodes, diodes are polarized. They work with brushed motors and speedos because the (+) wire always is (+) and the (-) is always (-).
By their nature all BL controller wires alternate (+)(-)(+)(-)(+)(-)(+)(-)(+)(-)... in order to fire the stator segments and make the rotor ...rotate. Thus there is no way to hook up a Schottky on a BL speedo with out blowing up the diode and/or the speedo.
When you are running a brushed motor with a BL controller you can run a Schottky just like normal soldered on to the motor tabs.
Adrian Martinez
Old 05-04-2006, 10:42 PM   #554
reilly's Avatar
Have a question,
My sphere comp. mode light toggles between red and amber and I have no
throttle. I have ck'd the sensor wiring harness, the motor and speedo were not
hot about 100 deg F, I have also tried a different BL motor with a different sensor harness, still nothing. Any advice??
Thanks,
James
CEFX, Express Motorsports, Parma, Reilly Paint
reilly is offline   Reply With Quote
Old 05-05-2006, 03:43 AM   #555
luke humphrey's Avatar
Hi there, i run the LRP Brushless also, and wen i 1st set it up i had the same problems, on the set up sheet u get with it, reset it and then go through the full process and then hope fully tht might help,check for dodgy wire connections and that the capacitor is in good condition,
regards Luke
luke humphrey is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
