Old 04-19-2006, 05:34 AM   #511
Originally Posted by Dragonfire
Check out Mics setup, using an old stiffner bar.
Pity I can't race brushless with you this weekend at SMA (i assume u r goin) as mine won't be in until next week. Good news is I opted for somthing better than a 4-star hehehehe
SMA is not on this weekend,
So what have you ordered?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-20-2006, 07:47 AM   #512
Sphere comp... but couldn't get a 4star (or 5star) so I got the 4.5r (novak). Bit of a risk since I haven't seen it perform well (at all actually) but from what I have been told about brushless problems it should be the best way to go.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 04-22-2006, 04:50 PM   #513
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Is there a replacement commutator for the NEO 3 star motor? I ran my today in a 12th scale race and ended up fliping several times. By the time I got back on my wheels, the car sounded like I had stripped my spur. What I found out when I got home to check the car out was that the Commutator or center stack had shifted tl where the shaft was no longer in the bottom bearing on the wiring side. I would hate to waste another $80 and change for a new motor. I have had this motor since October of last year. Some know anything??????
CarlosG. is offline   Reply With Quote
Old 04-25-2006, 09:18 AM   #514
Hello ALL
Where could I get a LRP Vector 4star motor?
And how would it compare to the Neo One 4 Star?
Thank you
Miu Miu is offline   Reply With Quote
Old 04-25-2006, 09:46 AM   #515
You can get them from most popular online shops or most probably through your local hobby shop as well
stormerhobbies.com has those
Lrp 4 star is exactly the same motor as Neo One 4star only with different stickers...
JanisK is offline   Reply With Quote
Old 04-25-2006, 06:13 PM   #516
lookinco's Avatar
NEED HELP!
For some reason, my LRP runs in reserve.
I followed the wiring diagram for brushed motor. A + B to negative and C to positive. The motor would run in reverse when hooked up this way.
If I reverse the wires, put A+B to positive and C to negative, the motor would run foward, but that's exactly the opposite of what the manuel says.
Also when running with brushless motor, the motor would stop once in a while and it also run in reverse!
This all happeend after I accidentally hooked up the A wire to the C tab and C wire to the A tab on the brushless motor. Is my ESC blown already? It seems to run fine in brushed mode except that it runs in reverse.
NEED HELP!
lookinco is offline   Reply With Quote
Old 04-25-2006, 07:13 PM   #517
Hey lookinco,
I have had the same problem b4....... so what you should do first is go and get your transmitter and flick thorugh it until it says throttle reverse or somethign similar and whatever it is on change it to the opposite.
If that doest work it could be your esc is hooked up the wrong way on your rx(reciever)
hope that helps
jamie
jamie814340 is offline   Reply With Quote
Old 04-25-2006, 08:06 PM   #518
lookinco's Avatar
I have tried that and it doesn't work. I don't think it has anything to do with the transmitter.
It was working all fine until I accidentally hooked up the wires incorrectly. Ever since then, the brushed motor would run in reverse. In brushless mode, the motor would run forward but would stop once in a while and won't start until I manually turn the rotor of the motor.
Old 04-25-2006, 10:54 PM   #519
Tech Legend
Wild Cherry's Avatar
Make sure the hall effect wire harness is plug in ,also check for a broken wire on plug...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-25-2006, 10:59 PM   #520
lookinco's Avatar
I have made sure the hall sensor wires was plugged in and all wires in the plug was fine.
The problem is not only in brushless mode. In brushed mode, the motor would run in reverse when hooked up according to the manual.
Before I hooked up the wires incorrectly, everything was working fine. So I think I might have screwed up the ESC when I switched the A and C wires when hooking up the brushless motor.
Anyone have experience with that? I have a 3 days trophie race coming up on friday, so I need to figure this out asap. If the ESC is broken, then I would need to order a new one ASAP.
If anyone could help, it's GREATLY apprecaited!!
Old 04-25-2006, 11:55 PM   #521
CarbonWorks's Avatar
I installed my new sphere comp in my zx-5 saturday. I was using a novak 6.5 motor. I made about 6 laps when my car slowed down and the speed control burst into flames. Is this what is referred to as thermal shutdown?
I can only guess that this was a fluke, since everyone else around here using that controller has only had good luck.
CarbonWorks is offline   Reply With Quote
Old 04-25-2006, 11:58 PM   #522
lookinco's Avatar
wow.........
that's a cool thermal shutdown....did you find out what caused the problem?
have anyone had experience like this?
Old 04-25-2006, 11:59 PM   #523
lol.....
Powered by Falco
Old 04-26-2006, 01:26 AM   #524
ngo8's Avatar
Send a message via ICQ to ngo8
does anyone know if you can inter change brushless motors with speed controls like use a novak speed control with lrp motor or vice versa ?
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 04-26-2006, 04:00 AM   #525
ben73's Avatar
Trader Rating: 40 (100%+)
Default lrp comp in xxx-4 with 3 star
hi guys
Burito or anyone with some experience in offroad - I have a question, do I need to run the heatsink with a 3 star in my losi 4wd car?
I am not running one with my 2wd and 1 star and all has been good. speed and drivebaility has been awesome and am looking forward to hooking up my 4wd tonight and racing on sunday...
thanks
Ben
ben73 is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
