Old 03-21-2006, 12:54 AM   #481
burito's Avatar
@azmio: I used to live at Pfaeffikerstrasse, you probably know the Renault car dealer there (which was my father...).
I'll get back to your mail from yesterday asap.
@Stealth: I don't understand your problem completely. Sorry.
Does it shutdown towards the end of the run of the first pack or is this happening after several packs?
Which motor and which gearing do you use?
Are you completely sure it's not a Spektrum shutdown?
Reto Koenig
burito is offline   Reply With Quote
Old 03-21-2006, 01:17 PM   #482
Hello Burito . I have a different question . Can I use Sphere with a 4-star brushless motor on my boat ? Is it create a problem ? Also what is the difference between Sphere and Sphere Competition ? Thanks
eskiserkan is offline   Reply With Quote
Old 03-22-2006, 12:38 AM   #483
burito's Avatar
With good cooling the 4-Star may work with the normal Sphere, but you'll definitely require a cooling fan and there's no guarantee it won't go into thermal shutdown. Sorry
Detailed differences between the Sphere and the Sphere Competition are visible on our website www.lrp-electronic.de
- different fet's
- different PCB
- different components
- different software
- different controller
Reto Koenig
Old 03-22-2006, 01:38 AM   #484
STEALTH's Avatar
Trader Rating: 21 (100%+)
burito - Many thanks for the reply. Actually, the problem happens towards the end of my first battery pack on my Associated T4. I have had no problems with 5 minute races...but I can't seem to finish practicing through a whole pack without the shutdown occurring (again, towards the end of my run).
At first I thought maybe the voltage on my pack got too low and it was that which caused some kind of automatic shutdown.... But when I tried using another full battery pack right after my run I have steering but only intermittent throttle control?! The Sphere ESC lights only flicker?! Only after about 10 minutes do I get back my throttle control?! It seems like symptoms of a thermal shutdown and the ESC just needs too cool-off but when I checked both my Sphere ESC and Motor (3* Neo-One) neither are very hot and if anything only warm?!
Again, I know I am not over-geared (87T Stock Spur with a 16T Pinion). I should be getting the cooling set in the mail by this weekend and only need the Cap since I already have a Much-More fan installed in my kit facing the Sphere ESC. Also, I doubt it is a Spektrum problem as I have already installed the Spektrum Cap to my transceiver and none of my other kits (B4, BJ4, etc.) have this problem... all use Spektrum gear with Novak Brushless Systems.
Well, if you have any tips, suggestions, or recommendations I definitely would appreciate it. Thanks again for your time!
STEALTH is offline   Reply With Quote
Old 04-08-2006, 06:21 PM   #485
SpeedyPenguin's Avatar
I have a LRP sphere/Neo 1 system with two motors a 1* and a 3*
We are having difficulty with the motors, the 3* works just fine once itgets moving but once it stops or goes into reverse it takes a spin of the armature to get it going again.
The 1* starts normally but it makes horrible sounding noises that sound like an "ack,ack"
Any Ideas?
SpeedyPenguin is offline   Reply With Quote
Old 04-10-2006, 02:23 AM   #486
mmgteam's Avatar
Send a message via AIM to mmgteam
For Burito:
How many drivers run with the Sphere+vector in the Ifmar Warm-up in Torino ???
What´s the ratio that they used ??
Team Orion win again with the V2 motors, they have big drivers I know .
mmgteam is offline   Reply With Quote
Old 04-12-2006, 07:21 AM   #487
burito's Avatar
Hello All, just returned from the Pre-Worlds Italy last night. We spent 2 extra days after the race for testing, unfortunately Monday was washed out with heavy rain...
It was a fantastic race for us, our new teamdriver Ronald Voelker did great in his first race with his LRP Brushless powered Cyclone.
It worked extremely well and he qualified 5th. He could have been 2nd with some more luck and a better heat, but we were very happy with the result anyway.
Other drivers/spectators were very impressed by the power/speed of our brushless system. Ronald clearly had the fastest car!
@mmgteam: entire team ran brushless, we had people like Ronald Voelker, Juho Levänen, Jonas Kaerup, Christer Andersson, Andy Kraemer, etc using it. Only Ronald made it into the Top10 tough, but it was certainly not the systems fault that others didn't make it.
We ran a ratio of 9.1:1 with 4-Star and 9.6:1 with prototype 5-Star motors, we used power-profile #5 and brake settings on #2.
Reto Koenig
Old 04-12-2006, 07:52 AM   #488
mmgteam's Avatar
Thank you very much for the info
Old 04-12-2006, 08:06 AM   #489
Ronald Voelker managed the third fastest run in the qualifying.
Only 2 sec behind Rheinard.
dave-foofighter is offline   Reply With Quote
Old 04-13-2006, 11:44 AM   #490
Burito, you have a PM
jarkko is offline   Reply With Quote
Old 04-13-2006, 11:59 AM   #491
burito's Avatar
@jarkko: sorry, I hate PM's... please send it to me by eMail, thanks!
Reto Koenig
Old 04-13-2006, 01:00 PM   #492
I found this information on novak brushless thread:
Novak Brushless:
3.5R (3.5 turns?) [rumored, not yet available]
4.5R (4.5 turns)
5.5R (5.5 turns)
6.5R (6.5 turns)
7.5R (7.5 turns)
5800 (8.5 turns)
4300 (10.5 turns)
Reedy Brushless:
5-Star (4.5 turns?) [rumored, not yet available]
4-Star (5.5 turns)
3-Star (6.5 turns)
2-Star (7.5 turns)
1-Star (8.5 turns)
If this is true, than currently available 4star motor is slower than novak’s currently available 4.5R brushless??
JanisK is offline   Reply With Quote
Old 04-13-2006, 01:13 PM   #493
Hi!
For burito (you have a PM but I have seen that don't like ):
The last week I was training with my 1/12 powered by matrix evo. and 4-stars motor in a very big track (asphalt) and I have a problem..
When I full-throttle the ESC it makes things rare during one moment (like if I have interferences) and later it returns to normal operation. I can solve the problem with a minipack at reciver (5 cell- 6v).
It's this normal in large tracks (roll-out:31mm)??
It's possible that the power capacitor is broken??
Greetings!!
Caza Roedores is offline   Reply With Quote
Old 04-13-2006, 01:18 PM   #494
burito's Avatar
@janisk: that winding information is correct, we don't make a secret about the winds anylonger.
Well, it's not all about the number of turns! Our 4-Star (5.5t) is damn fast already...
@caza: so you say that it normally works fine and that it's only a small problem when you hit full throttle. Right?
A receiver pack (5 cells) is recommended for 1/12 use, but some drivers ran it with no problem at the euro's with no receiver pack. It just doesn't work flawlessly with all receivers when no receiver pack is used.
Which power profile do you use? I'd recommend #3 for 1/12.
Reto Koenig
Old 04-13-2006, 01:57 PM   #495
Burito thanks for answer!
Is there any news when 5start gonna be available in europe?
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
