Old 05-04-2005, 12:53 PM   #1
Default Stock motor temp
What temp should you motor be running around? I dont wan tto burn my brushes. i am runging a stock motor.
Luke
rcracer333 is offline   Reply With Quote
Old 05-04-2005, 01:02 PM   #2
polesitter61's Avatar
Between 130 to 160 degrees is pretty good. Anything more than that seems to discolor the com pretty bad.
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 05-04-2005, 01:04 PM   #3
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
THE BEST WAY TO DETERMINE THE TEMP IS IF YOU CANT KEEP YOUR HAND ON IT MORE THEN A COUPLE SECONDS, IT TOOOO HOT. GEAR DOWN
BIG DADDY8 is offline   Reply With Quote
Old 05-04-2005, 01:12 PM   #4
Luke,
Gear the motor for the track & don't worry about temp to much. You should gear so that the car reaches top speed about 3/4 down the strait, then adjust for the fastest lap times. The only time you should be conserned about temp is when the motor starts to fade in the 5min run. I should be out to the race on the 14th and me or Dom will help you out.
Chad
ChadK is offline   Reply With Quote
Old 05-04-2005, 01:12 PM   #5
Ok thank i got a temp gun so around 150 would be good? thanks guys
Luke
Old 05-04-2005, 01:15 PM   #6
Ok thank i was having really horable truble last time my motor was runing like 200 and i kep buring my brushes. tahnks for offering to help me. I thing i will jsut set up by you guys if you dont mind?
Luke
Old 05-04-2005, 01:20 PM   #7
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
it also depends on how hot it is out side and how how the track is . like you are geard perfectly for your track but after your run you touch your motor and its SUPER HOT that you cant even touch it but thats only cause the temp of track and the temp it is outside.
Roberto Falcon is offline   Reply With Quote
Old 05-04-2005, 01:26 PM   #8
Fran's Avatar
Trader Rating: 157 (100%+)
loSi xXxs, do you use any heatsinks on your motor w/ your Mi2?
Roadrunnersrc.com
Team Associated 12R5.2
Team Associated TC6.2
Team Associated TC7.1
Team Associated F6
Fran is offline   Reply With Quote
Old 05-04-2005, 01:27 PM   #9
nope.. why?
Old 05-04-2005, 01:29 PM   #10
Fran's Avatar
Just curious. I'm currently experementing with my Mi2 and a vented style clamp from 3 racing, it's designed to allow the vent holes in the can not to be blocked. Just curious ...
Roadrunnersrc.com
Team Associated F6
Old 05-04-2005, 01:31 PM   #11
Ok.....for those of you that think your motor is getting hot only because it is overgeared are wrong. Your motor could be geared just right but your bearings suck and your putting an excess load on the motor. Most of the time I find that guys are way undergeared because they are afraid of being over geared and that burns up the motor just as fast. Ask the guys around the track what their motors temp, gearing, springs, and brushes are and you should never burn up a motor.
mtc3od is offline   Reply With Quote
Old 05-04-2005, 10:26 PM   #12
eforer's Avatar
Send a message via AIM to eforer
one thing to keep in mind when temp gunning motors is that the cans are shiny. You need to adjust the emmisivity of your temp gun to compensate for the reflectivity of the material other wise your readings will be totally out ot lunch. You notice this effect in more dramatic fashion if you temp gun a chrome pipe, it will read really low even though its generally much hotter than the head on a nitro motor.
Speed Merchant/Corally USA/Specialized RC/Team Kwik/Tekin/Sweep/Parma PSE/Team Pickles Performance
eforer is offline   Reply With Quote
Old 05-04-2005, 10:40 PM   #13
axel's Avatar
for some reason for me switching from 48p to 64p helped A LOT.
axel is offline   Reply With Quote
Old 05-05-2005, 12:20 AM   #14
RDR
RDR's Avatar
I ram my Monster Stock @ 190 last time I raced, brushes, and comm looks like they could do another race night at that temp again.
RDR is offline   Reply With Quote
motor temp Flying Monkey Electric Off-Road 8 05-15-2008 08:35 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
WTT: XTM 24.7 motor for temp gun nitro2go R/C Items: For Sale/Trade 0 04-18-2005 02:12 PM
Trinity Stock P2K Pro 375 degree on Temp gun Nova F1 Racer Electric On-Road 14 03-15-2004 03:31 PM
