Old 05-04-2005, 10:23 PM   #16
Hyperform Racing's Avatar
Originally posted by eforer
if you want to do a pwm type of deal and alter the duty cycle555lm cmos timer from radio shack. You can reduce the voltage going to the chip to logic level (+5v) with the good ol r-shack voltage regulator which would eliminate the need for a ginourmous resistor. You set the freq by placing resistors and a capacitor across a couple of pins. I used one recently in a voltage multiplier but the concept works for reduction as well. You will need some sort of transistor drive to handle the current going to the motor via a mosfet , you can setup a totem pole arrangement (non-inverting) with an npn/pnp combo of transistors which can be used to drive a mosfet(s). If you want to google non-inverting bi-polar totem pole, you can get a schematic for the driver. The mosfets you just wire in parallel until they handle enough amperage, 3 irf510s (availible at radio shack) should be enough.
uh, wha?
Hyperform Racing
www.Hyperform-Racing.com
[email protected]
(978) 416-2572
Hyperform Racing is offline   Reply With Quote
Old 05-04-2005, 10:31 PM   #17
eforer's Avatar
Send a message via AIM to eforer
just look up dc to dc conversion with square wave or pwm. There are a lot of easy-ish ways to do it with radio shack parts.
Speed Merchant/Corally USA/Specialized RC/Team Kwik/Tekin/Sweep/Parma PSE/Team Pickles Performance
eforer is offline   Reply With Quote
Old 05-04-2005, 10:42 PM   #18
eforer's Avatar
if I made something that you hooked up to a power supply and allowed you to adjust motor speed for lathes etc that could handle 20 amps would people pay $50.00 for them? Thoughts anybody?
Old 05-04-2005, 11:01 PM   #19
yes
Hyperform Racing
[email protected]
(978) 416-2572
Old 05-04-2005, 11:07 PM   #20
yokomo makes a motor mate. to run lathes and break in motors
baih is offline   Reply With Quote
Old 05-04-2005, 11:19 PM   #21
eforer's Avatar
guess that shoots that in the foot
Reducing Inventory Riketsu R/C Items: For Sale/Trade 6 04-21-2007 08:30 PM
Reducing IR in Batteries Paladin Electric On-Road 3 10-29-2005 12:06 AM
Proper reducing for Pactra? polesitter61 Painting, Designs, Graphics and Photography 5 06-04-2005 08:04 PM
Electrical Gurus - Reducing 6v hawker Electric On-Road 7 05-12-2005 12:50 PM
reducing slope? jcr Electric On-Road 18 04-14-2003 08:59 PM
