Old 05-03-2005, 03:23 PM   #1
Trader Rating: 17 (100%+)
Default question about scoti diode
Which scoti diode should i choose 100v 3 amp or 400v 3amp???
the scoti diode that came with qc2 was 400v 0.75amp (540bl).
the higher amp the scoti diode is better or the voltage? thanks.
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 05-03-2005, 03:41 PM   #2
rc_bam226's Avatar
A higher amp one is advisable.
rc_bam226 is offline   Reply With Quote
Old 05-03-2005, 10:12 PM   #3
ok scoti diode getting the higher amp...how about the voltage???
will 100v be sufficient or 400 volt will be better...thanks.
another q. for power capacitor...which 1 is better 16v 6800uf or 25v 6800uf. sumone plz help.thanks...
Tamiya TB Evo 5
Old 05-03-2005, 10:49 PM   #4
Send a message via AIM to micros_rock
Get the 16v cap, 25v is more than you need, it would just take longer to charge up.
micros_rock is offline   Reply With Quote
Old 05-04-2005, 01:18 AM   #5
get the 16 V it will be smaller and take a cap with a low ir and who can work at hiqh frequencies.
The diode must be a Schottky diode
one of the best axial diode will be the ref 90SQ040 (9A diode)
You can use some diode in to220 size that you can (like the novak 35 A) leave that on the speedo.
of course it's better to place a diode near the motor.
Hope you anderstand me because i'm french !
simon is offline   Reply With Quote
Old 05-04-2005, 02:04 AM   #6
asw7576's Avatar
Schottky diodes: bigger amp is better than voltage. See my attachment for the ultimate schottky diodes.
Capacitor : bigger capacity ( uF ) is better up to certain limit. Too big size cause unnecessary weight and even less performance. 16V rating is good for RC application. Try to find low ESR type ( fast charge / discharge ) you could easily find them from older computer motherboards like Pentium 2 and 3.
Old 05-04-2005, 09:52 PM   #7
thanks everyone...i saw the kopropo power capicitor was 25v 2700uf not sure about the uf does bigger uf help alot or any will do?thanks
and wouldnt the esc burn as it is rated to operate at 4.8~8.4v...while the diode 1s 25v.
Tamiya TB Evo 5
Old 05-04-2005, 09:57 PM   #8
i am a lil confused the diode is 3 led diode, how am i going to mount to the motor.thanks.
Tamiya TB Evo 5
Old 05-04-2005, 10:11 PM   #9
eforer's Avatar
Send a message via AIM to eforer
uf is the measurement microfarad. Capacitors basically store electrical current and in the case of an RC application release it quickly when a path to ground (ie neg batt) is made availible by nailing the throttle. It improves punch in stock 19t by allowing a rapid release of amperage to the motor, but is also useful in all forms of rc because it helps to reduce emf related intereference caused by the high current components of an rc car. The schoktty diode (like all diodes) only allows current to flow in 1 direction. When you apply the brakes current flows back into the speedo from the motor and can damage the breaking fets if it is too high, or in the case of some speedos virtually any reverse current is damaging (the KO's come to mind). The link posted previously is awesome and really overkill (in a good way!). + I am sure buying it from an electrical supply distributor like newark or mouser will cost a lot less than comprable KO ultimate schokkty which costs $40!
Speed Merchant/Corally USA/Specialized RC/Team Kwik/Tekin/Sweep/Parma PSE/Team Pickles Performance
eforer is offline   Reply With Quote
Old 05-04-2005, 10:18 PM   #10
about the power capicitor higher uf will do better job then the lower uf???
does we use smaller uf for stock and 19t since it draw smaller amp and bigger for mods???
thanks
Tamiya TB Evo 5
Old 05-04-2005, 10:25 PM   #11
diesel's Avatar
Default model number
Engtat: Can i have the model number of the schottky diode your using? Its printed on the diode itself. Thanks.
diesel is offline   Reply With Quote
Old 05-04-2005, 10:31 PM   #12
Default Re: model number
time being i am just using in5401 and sb540bl(ori from qc2)
Tamiya TB Evo 5
Old 05-04-2005, 10:35 PM   #13
eforer's Avatar
4700 uf (make sure it can handle the voltage) is around the right area. Although I've seen people use up to 10000uf caps.
Old 05-04-2005, 10:41 PM   #14
voltage...is the 16v 6800uf ok? of higher v is better?ko propo 1s is 25v if not mistaken.
Tamiya TB Evo 5
Old 05-04-2005, 10:43 PM   #15
diesel do u now how much is the ko scoti diode the old model when like printed board, i can t remember the part number. my lhs is selling rm28 i think.
Tamiya TB Evo 5
diode & super capacitor question nikkiesteban Electric On-Road 2 01-30-2007 11:56 PM
diode harddrive Electric On-Road 10 02-27-2006 10:40 PM
Diode dilemma......(a quick question).... Mabuchi540 Electric On-Road 1 09-18-2004 04:42 PM
Schottey Diode TRF-Powered Electric On-Road 19 05-21-2002 11:58 PM
Schottky Diode Placement Question mike_Webb Electric On-Road 17 03-27-2002 02:20 PM
